-   -   taping and finishing inside corners (http://www.diychatroom.com/f101/taping-finishing-inside-corners-92825/)
drewhart 01-19-2011 12:24 PM
my wrist has been hurting lately from using knives and pan. is there a way to tape and or finish inside corners using the hawk and trowel? it always comes out too sloppy.
CplDevilDog 01-19-2011 12:36 PM
Practice :thumbsup:
redmanblackdog 01-19-2011 04:21 PM
Are you using a 4 inch knife? Takes less mud than a 6".
firehawkmph 01-19-2011 05:10 PM
6" knife works good for corners without being overly big. I always switch hands every so often. If the corners are coming out sloppy, it won't be any different with a hawk and trowel, probably worse. Don't load your knife up too much and take your time.
Mike Hawkins:)
Gary in WA 01-20-2011 12:53 AM
This guy is good; if this one is not the inside corners, he has many more others nearby; http://www.youtube.com/watch?v=21GBDgkL3WE&NR=1
Gary
drewhart 01-21-2011 12:05 PM
i tape with the 4" and finish with the 6" for finish ill do one side of the corner with the 6" then the next day do the other side. i just wondered if anyone ever used the trowel for corners.
redmanblackdog 01-21-2011 12:50 PM
They do make a corner trowel, that you can finish both sides at the same time. I found that they are usually more rounded than square when you get done. Thus causing trouble with areas like baseboard trim.
bjbatlanta 01-22-2011 01:13 PM
I wouldn't recommend a corner trowel. Drewhart's advice is sound. Personally, I use a 5" knife for taping and bed coat on angles...
Gymschu 01-22-2011 02:30 PM
Just use caulking......if you have wallboard that's nice and tight at the inside corners, caulking saves you so much work. I know many will criticize me for saying so, but I've done it for years with no callbacks.
bjbatlanta 01-22-2011 03:14 PM
I wouldn't recommend that either....
firehawkmph 01-23-2011 02:47 PM
People like you keep me very busy. I just started tearing out a 'finished basement' in a million dollar home friday do to shoddy work. Thanks,
Mike Hawkins:)
tcleve4911 01-23-2011 02:57 PM
Gary
Frenchmen have ALWAYS been the best tapers.
With a name like Laurier Desormeaux you know he's gonna be good!!!
Good video der!!!
oldrivers 01-23-2011 06:08 PM
for a diyer i wouldnt advise a corner trowel , they take time to get used to and are more for the professional ... plus id advise using a banjo for taping at minumin.. taping like that is to slow bedding with a knife ..use a banjo ...
Gymschu 01-23-2011 11:26 PM
Mike Hawkins:)
Mike, it wasn't a truly serious suggestion, but, since the poor guy was saying how sloppy his inside corners were, I provided a solution, maybe not entirely a professional solution......however, I've done it in a pinch, returned to the job even years later and the corners are just as tight as any finished drywall corner. It's an option......:)
williamwiens 01-24-2011 08:05 AM
i use 20 min mud for corners especially.
I do the one side of all corners and by the time I do the last corner the first one is ready for the second side.
When it comes to finish coat, one side per day.
