Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 05-13-2009, 04:27 PM   #1
Taping drywall - overlap paper tape or not?
The websites I've been reading seem to disagree with eachother. Some say to overlap, some say to avoid overlapping and others don't say anything about it. Which is it? If overlap, how much? all the way through?
I appreciate the help.
Also, am i correct in order of taping 1. buttjoints 2. recessed joints 3. corners?
newbpainter is offline   Reply With Quote
Old 05-13-2009, 05:46 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Simple answer: Overlap.
- Build Well -
Old 05-14-2009, 05:40 PM   #3
Drywall Contractor
LadyFinisher's Avatar
What are you overlapping?
Where two seams come together?
Or where you were taping and ran out of tape then started using a new roll?
"taping 1. buttjoints 2. recessed joints 3. corners"
will work, some people do it in a different order, if you like the result that's what matters but I always do the corners last
LadyFinisher is offline   Reply With Quote
Old 05-17-2009, 08:01 AM   #4
i prefer to run my angles first,bevels,then butt joints...i find this illiminates a lot of contact with butt joint and bevel tape with your flusher head...overlap your tape only by 1/4 inch,sometimesits fiba tape bevel joints ,paper tape bevels..with very thin layers(tight)of sheetrock 45 as a prefill to just give them the xtra strength..then the 2 other coats following in regular boxed compound...cgc light,or xtra light...
HOMEY is offline   Reply With Quote
Old 05-17-2009, 11:10 PM   #5
not expensive at all,,very straight forward none of the procedure is money costing..mostly just experience...plan ahead ...if you follow these steps it will work...even if you screw up there are ways that are simple to fix it ...just ask..
Taping drywall joints - fiber glass mesh or paper? RickT Painting 25 04-20-2011 10:09 PM
Drywall Taping - do you apply a layer of mud over the tape on your first go? newbpainter Drywall & Plaster 20 05-18-2009 07:43 AM
Frustrated by paper along side of drywall J187 Drywall & Plaster 6 04-22-2009 06:29 PM
drywall tape coming off jlajla24 Drywall & Plaster 5 12-04-2008 10:27 PM
How to use non-adhesive drywall tape? tripower Building & Construction 1 05-28-2007 10:29 AM
