Taping Corner Bead? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-01-2010, 07:30 AM   #1
Rewards Points: 31
Taping corner bead?
I installed metal corner beads. I'm wondering if I should apply paper tape over where the flanges meet the drywall. The reason I ask is that I saw this Sheetrock corner bead at Home Depot and the paper is built into it.
kupalino is offline   Reply With Quote
Old 03-01-2010, 07:54 AM   #2
Remodeling Contractor
that is just another type. it gets mud in back and on top just like seams. Corner tape needs no paper tape Flex the corner closed a little and secure to the corner. It must stick out a little at the corner and then fill with durabond 90, not premixed mud. The mix it your self type is much harder and leaves a stronger corner.
Old 05-03-2010, 03:18 PM   #3
Rewards Points: 262
Bob,
Do you prefer the metal beads or the plastic mesh kind? Fasten with nails or screws? Just curious.
Thanks.
tpagel is offline   Reply With Quote
Old 05-07-2010, 08:58 AM   #4
Drywall contractor
Rewards Points: 1,070
The mud-on beads are actually the best as far as resisting cracking and "popping" loose. Metal should be nailed on. I don't use plastic, but I would nail it also. Screws often don't pull up tight....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Paper faced Metal inside/outside corners? slinku2020 Remodeling 6 03-20-2009 10:16 PM
drywall corner bead drewhart Drywall & Plaster 2 10-22-2008 09:28 AM
corner bead on existing wall stallinc Building & Construction 12 01-30-2008 07:38 AM
Drywall corner bead Question dk_99 Building & Construction 5 01-01-2008 03:25 PM
Mounting corner Bead KUIPORNG Remodeling 7 01-04-2007 08:20 AM
