Tapered Drywall Edge Along Floor - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-12-2012, 10:42 PM   #1
Tapered drywall edge along floor
Ey guys so I go a new dilemma. Taped and missed drywall with tapered edge at base of wall. I plan on putting baseboard. Do I simply put compound along base of wall or should be fine with baseboard covering tapered edge.
The drywall starts an inch off ground.
Aloha1 is offline   Reply With Quote
Old 01-12-2012, 10:57 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
No. Don't tape it.
If you're concerned with the base rolling, set a little block of base below the sheetrock every 4 feet or so when you go to install the base.
Sent from a Samsung Galaxy SII
titanoman is offline   Reply With Quote
The Following User Says Thank You to titanoman For This Useful Post:
mae-ling (01-12-2012)
Old 01-12-2012, 11:03 PM   #3
Rewards Points: 2,202
That is if your base will cover it. Seen base that was 1.25 inches.
mae-ling is offline   Reply With Quote
Old 01-12-2012, 11:19 PM   #4
Disabled wood vet
titanoman's Avatar
Thats pretty small. 2 1/4's what I'm used to.
(and a little 6x3/4 and used those inside and outside corner blocks).
Old 01-13-2012, 12:01 AM   #5
I've even put base in a house that had to base. Just the drywall right down to the carpet, that was the 'modern look'
Old 01-13-2012, 08:10 AM   #6
Mold!! Let's kill it!
Rewards Points: 2,012
Guess they didn't run a vacuum like my wife does.
The Following User Says Thank You to Maintenance 6 For This Useful Post:
mae-ling (01-13-2012)
Old 01-13-2012, 08:33 AM   #7
A Little Of Everything
Rewards Points: 1,362
Assuming you're using the standard 3-1/4" base trim, coverage should be fine. Shim the bottom, don't mud it.
DrHicks is online now   Reply With Quote
Old 01-13-2012, 08:49 AM   #8
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
When I see this detail, I "Shim" the bottom with drywall screws set flush to the plane of the wall.
I install them about every foot or so and it holds the bottom of your baseboard out. This avoids having to cut and fasten little blocks everywhere.
tcleve4911 is offline   Reply With Quote
Old 01-13-2012, 08:50 AM   #9
What do you use for shim? Do you rip 1/4" plywood?
Old 01-13-2012, 08:53 AM   #10
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
No shims
Just set a screw in the bottom plate so the head sticks out 1/2"
This will hold the back side of the baseboard out so it sits flat to the non-tapered part of the drywall.
Old 01-13-2012, 09:00 AM   #11
No shims
Ahhh... Thanks! I completely mis-read, and mis-understood what you were saying.
Old 01-13-2012, 09:03 AM   #12
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
I should take a picture of that the next time I do it. I use this trick a lot but when I try to explain it....well you know.....
Glad you grasped the concept. It really works well.
Old 01-13-2012, 09:09 AM   #13
It makes perfect sense, now that I understand it. I'll definitely do it that way, next time I have to "shim" trim. Thanks!
Old 01-13-2012, 12:30 PM   #14
Wow thanks guys. Learning new tricks helps choke!
Much mahalos!
Old 01-13-2012, 03:15 PM   #15
The screw trick also works good in corners where you need to kick out the bottom edge of the baseboard a little for the coped piece going over it to fit tightly. (or mitred if you do it that way)
If using screws make sure you do not hit them with your air nails. It will curve them back out the front.
If using plywood use 1/2" or whatever your drywall is. If you have a bunch to do plywood and our brad or finish nailer is quick, don't need to be continuous, just say 3-4" strips every couple of feet and at corners.
How to anchor toilet flange to porcelain tile? bobmg Plumbing 32 08-19-2013 10:32 PM
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 02:37 PM
Floor Drain Against Drywall acerunner Building & Construction 4 09-29-2011 02:01 PM
Patching drywall at floor level... daballenger Drywall & Plaster 2 05-07-2010 09:45 AM
Rotted floor joists and wall edge Jim F Off Topic 2 03-09-2010 10:37 AM
