Tape Showing - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-09-2011, 08:40 AM   #1
Rewards Points: 81
Tape Showing
I had a crack in the drywall. I mudded it, and put on a small piece of tape, and then mudded on top. Sanded it down, and applied another skimcoat on top with a wider knife. When I sand it down, the top of the tape in a small section wants to show. The tape is on solid, no bubbling or liftng. But, whenever I try to sand down to make it flush with the surrounding wall, this part of the tape shows. It is not the edges of the tape that is showing, but a small area in the middle part of the tape. Can I just prime over this and try to skim coat once more? Or, should I build this area up a little more than the surrounding area and feather the edges in to disguise it? Fortunately, it is near the door, and I think the door casing will cover this part of the tape anyways.
cougar01 is offline   Reply With Quote
Old 03-09-2011, 08:58 AM   #2
If the crack was real small I would have caulked. If not, dig out the old tape and set new
dvatt is offline   Reply With Quote
Old 03-09-2011, 09:32 AM   #3
Hey cougar01,
I think your second idea is the better one. If the tape shows after you sand it smooth you need to build up that area. Use a little more compound and fan it out wider. You want a gradual incline so don't be afraid to spread it further than you did before. You also don't need to add a lot of pressure and don't feel bad if it takes a few more times. Good luck. -Gregg
gotogregg is offline   Reply With Quote
Old 03-09-2011, 04:21 PM   #4
Drywall contractor
Rewards Points: 1,070
If it feels smooth, paint it. Tape is a "paintable" surface. As long as there is not a discernible edge, it should be fine. If you keep adding mud, you'll end up with a "bump".
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Effects of electrician tape on cable richard7994 Electrical 4 08-11-2010 08:39 AM
Paint problems....or just problems with the painter... deanswife Painting 5 07-30-2010 08:36 AM
Aged Painting Tape Needs to Come Off user1007 Painting 2 03-04-2010 05:16 PM
Frozen Hot Water Pipes TravisW Plumbing 11 12-10-2009 05:26 PM
Masking and Blue tape ripping off paint LeviDIY Painting 20 10-21-2009 06:56 PM
