Tape With Setting Mud - Yay Or Nay - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 11-08-2011, 09:19 AM   #1
Rewards Points: 290
Tape with Setting Mud - Yay or Nay
Found some old threads suggesting that setting mud cracks more easily than regular bucket. But alot of these are also pro paper and no ~mesh~.
I'm leaning on doing setting mud/ Fibafuse and then topcoat with bucket jc.
We got flooded so I cut the lower 48" across the entire room. So the joint will be a butt joint with a tapered joint on the other. I like the Fibafuse as it's ~thinner~ than paper on the joint...
Some references the issue with setting mud / crack and new construction.
My house is around 70 years old. It's well settled if this matters....
mobiledynamics is offline   Reply With Quote
Old 11-08-2011, 10:20 AM   #2
A Little Of Everything
Rewards Points: 1,364
I'm not sure exactly what you're asking, but usually the green-lid drywall mud is used for setting the paper, and the blue-lid mud is used for top-coating.
Green lid mud has adhesive, blue lid is smoother.
DrHicks is offline   Reply With Quote
Old 11-08-2011, 12:04 PM   #3
Next Time...New Build
Rewards Points: 150
Just make sure if you are using mesh to use the durabond. I did your same project at my house with mesh tape and green lid mud and now see a hairline crack along that joint. The house is 90 years old so I don't think it is a settling thing.
Not sure if it was the mesh and green lid combo or not but be aware of that.
Never had the problem with paper and green lid.
RickyBobby is offline   Reply With Quote
Old 11-09-2011, 12:16 AM   #4
iminaquagmire's Avatar
Rewards Points: 338
Mesh cracks out on joints. It doesn't take much movement. Never use it for more than small patches. Use the green lid for your tape coat as it has the stickiness to properly bed the tape. You can use setting type after that.
iminaquagmire is offline   Reply With Quote
Scotch Edgelock Tape: My afternoon entertainment bokeh Painting 5 06-20-2011 09:17 PM
Burner always stops at LOW setting on L8124L pleasehelpmike HVAC 2 01-19-2011 08:22 AM
Tape Setting Idea Ptron Drywall & Plaster 10 09-10-2010 01:28 PM
Paint problems....or just problems with the painter... deanswife Painting 5 07-30-2010 08:36 AM
Frozen Hot Water Pipes TravisW Plumbing 11 12-10-2009 05:26 PM
