Tape Setting Idea - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 09-08-2010, 02:34 PM   #1
Rewards Points: 79
Tape Setting Idea
Anybody ever use a seam roller or something of the like to set tape in? I've always had a hard time squeezing all the excess mud out and getting tape flat when taping two even, matched surfaces, i.e. where minimal buildup is prefered. Seems if I run the knife over enough times or press hard enugh to squeeze out all the excess mud, I start to rough up the tape and/or it starts to bunch and shift around.
Also, I wonder why they don't make extra thin tape or mesh for this situation. Probably have to be made out of a fancier material but I'd pay for it in this situation (repairs to otherwise fine plaster.)
Ptron is offline   Reply With Quote
Old 09-08-2010, 02:42 PM   #2
Old School
Willie T's Avatar
Take a look at this...
http://www.butttaper.com/nightmare.htm
Willie T
Old 09-08-2010, 03:01 PM   #3
Rewards Points: 79
I took a look at the BUTT TAPER system. And it does look cool - for 200 with shipping it is worth it if you do enough work to justify it. I'd probably have bought one 20 years ago. If you don't do alot of the drywalling tho - it seems to me that adding nailers to crooked joist/studs as needed and gluing and nailing on new work (ok Or screwing) is just as good as long as you make the area wider that you feather out. I just got into white coating everything. Even if i subbed it out, it was still cheap and does a great looking job. A plastered apperance. So just get into putting on that second coat like cream cheese with a knife and wider - heck you'll probably get into white coating too. One thing I did learn quickly was use sandpaper sparingly (cough cough)
If you don't have time to do it right, when will you ever have time to do it over?
jackofmany is offline   Reply With Quote
Old 09-08-2010, 03:22 PM   #4
Old School
Willie T's Avatar
If you are talking about normal butt joints, have you tried using "butt boards" and breaking your sheets between studs... not on them? It really works very well for keeping butt joints no wider than tapered edges.
Willie T
Old 09-08-2010, 03:26 PM   #5
Rewards Points: 79
Interesting, but I was talking about a flat surfaces, not corners. In my particular case I'm replacing large squares I cut out of plaster to do some electrical work.
Old 09-08-2010, 03:33 PM   #6
Rewards Points: 79
I'm fixing access holes cut in plaster walls. No tapered edges. (I wish there were tapered edges to set the atape into). In some cases I'm replacing the missing plaster with drywall in other places I was able to salvage the plaster squares (it's plaster over drywall not plaster over lathe. Sounds weird but that's what it is and yes, it's original) so I end up with nice evenly matched surfaces just with a big square cut to patch over. Hence not wanting a lot of buildup of mud.
Old 09-08-2010, 04:10 PM   #7
lowes actually has a sticky paper tape on the shelf now. doesn't work worth a damn in corners but it does on flat joints. it's more expensive but does save you doing a set coat. it works basically like glass tape, just happens to be paper
racebum is offline   Reply With Quote
Old 09-08-2010, 06:44 PM   #8
Phoenix
Anybody ever tried (plastic corner bead) spray ahesive to hold paper tape on before a first coat? It works.
Axecutioner-B is offline   Reply With Quote
Old 09-09-2010, 01:05 PM   #9
Rewards Points: 79
I tried the roller thing last night with a lint roller, heh heh. Not really the right tool but good enough to test the idea. It actually worked ok. Better than mangling the tape trying to squeeze out the excess mud and get it flat with a taping knife.
I think something like this would work pretty well. http://www.crutchfield.com/p_1541000...r.html?tp=2277
I think they're for inking engraved plates for prints or something like that.
Old 09-09-2010, 08:47 PM   #10
Rewards Points: 286
Ptron check out this thread for patching holes. Patching drywall with smaller piece
Jim F is offline   Reply With Quote
Old 09-10-2010, 01:28 PM   #11
Rewards Points: 79
Just a heads up should anyone want to try this. Apparently the roller trick can work too well. I had a couple small spots where I must have squeezed out too much mud and the paper didn't stick. Like I said they were small spots, easily dealt with, and it only occured in a couple spots over five patches. Overall, I think it actually worked pretty well.
I've done that Chicago patch thing before. Very handy. Though I recall having a similar problem with squeezing the excess mud out without mangling the paper.
First time taping - Tape has air under it theedudenator Drywall & Plaster 16 04-21-2010 11:13 PM
peeled primer (left the blue tape on too long) tjmack Painting 2 02-25-2010 12:16 PM
Freezer not cold enough at "normal" setting... skipjack Appliances 2 02-01-2010 03:10 PM
Paint pull-up!?!? with BM Aura Bath & Spa, GE Silicone II, and PM Green tape DIYatHome Painting 8 12-12-2009 03:52 AM
drywall tape coming off jlajla24 Drywall & Plaster 5 12-04-2008 09:27 PM
