Is Tape Required On All Patches ? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-26-2012, 07:57 PM   #1
Rewards Points: 296
Is Tape Required on all patches ?
I'm not talking about sheet seams, corners, etc
If you make a 6' square patch for example, and the patch is tight.....can one just mud over the butt-lines ? Paper, etc I need to float out the square much more to make it blend.....whereas without the paper, I don't get the buildout.
mobiledynamics is offline   Reply With Quote
Old 03-26-2012, 08:29 PM   #2
firehawkmph's Avatar
Rewards Points: 1,922
Without paper or mesh, it will more than likely crack along the patch over time. I use the ultra thin mesh and like it. Some guys like paper more. I just happen to like the mesh and am able to a good job with it.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 03-26-2012, 09:09 PM   #3
Haverhill Trade 1965
All joints might crack without it. Better than tape go to the golden arches order something to go. Their bags make a great one piece patch tape because they are thin. cut it an inch or so larger than patch, dampen it, spread a thin layer of compound put piece on & smooth it in from center out. Paper is thin enough so compound on patch can be feathered out so it doesn't show.
Duckweather is offline   Reply With Quote
Old 03-26-2012, 09:28 PM   #4
or you can do a california patch. You tube that and watch the first vid that comes up.
btyking is offline   Reply With Quote
The Following 2 Users Say Thank You to btyking For This Useful Post:
bbo (04-01-2012), oh'mike (04-03-2012)
Old 03-28-2012, 08:08 PM   #5
I was going to say the same thing. No backing and no screws needed.
kj6887 is offline   Reply With Quote
The Following User Says Thank You to kj6887 For This Useful Post:
bbo (04-01-2012)
Old 03-28-2012, 11:00 PM   #6
Rewards Points: 1,484
Or you can do a california patch. You tube that and watch the first vid that comes up.
I've used this same method for some patches that were even larger when the patch spanned a stud or rafter.
It's just so much easier....
ktkelly is offline   Reply With Quote
Old 03-29-2012, 07:33 AM   #7
Next Time...New Build
Rewards Points: 150
We call them a "Buffalo Patch." Must be a geographical thing.
They work great, especially when you cut out a junction box on the wrong end/side of the board.
Definitely never heard of using a McDonald's bag, that is a new one for sure.
RickyBobby is offline   Reply With Quote
Old 04-01-2012, 12:16 PM   #8
Drywall contractor
Rewards Points: 1,070
Around here they're called "hot patches". Otherwise, YES, you need to tape....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 04-01-2012, 02:05 PM   #9
If you want to take it a step further...
Do just as the typical "California Patch" video shows. and then"
Cut the facing paper, around the hole you're patching, an equal amount that you've left for the overlap, and "butter" in the same way.
What that does is have the paper facing of your patch at the same level as the paper on the wall.
It's a little more work but it's easier to have a smooth and level patch...
Let's call this the "Kelly Patch"....
Old 04-01-2012, 04:44 PM   #10
the Musigician
DangerMouse's Avatar
....now if I could just watch the damn video so I knew what the heck you were all talking about.....
DM
Old 04-01-2012, 06:32 PM   #11
Drywall contractor
Come on Mouse, first off you have to have more than Windows 95.....(lol)
Old 04-01-2012, 07:21 PM   #12
the Musigician
Still can't upgrade to win 95 yet. I can't afford it..... How is it?
DM
Old 04-01-2012, 07:57 PM   #13
bbo
DM
c:> not bad , from what I heard, its got this "multi-tasking" thing you can do.
bbo is offline   Reply With Quote
Old 04-02-2012, 10:40 PM   #14
Registered User
Rewards Points: 526
Levels 1-5 require tape: http://www.lafargenorthamerica.com/G...%20English.pdf
Gary
Is tape necessary to repair holes in drywall (in garage)? Scotch99 Drywall & Plaster 4 08-22-2011 01:08 PM
Roof heat tape installation options daroepke Roofing/Siding 0 06-25-2010 12:36 PM
First time taping - Tape has air under it theedudenator Drywall & Plaster 16 04-21-2010 11:13 PM
Paint pull-up!?!? with BM Aura Bath & Spa, GE Silicone II, and PM Green tape DIYatHome Painting 8 12-12-2009 03:52 AM
Drywall Mudding - Tape Lifting Drywall_Dummy Building & Construction 5 09-06-2005 11:53 AM
