Tape Joint Over Corner Bead? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 09-25-2011, 11:20 AM   #1
Rewards Points: 462
Tape joint over corner bead?
Quick question that hopefully has an easy answer.
In the basement where the staircase ends, the wall ends with a corner bead. I want to extend this wall all the way across the basement. Do I need to tear out the corner bead or can the new drywall be butted up against the corner bead and taped/mudded over?
Thanks.
Richo is offline   Reply With Quote
Old 09-25-2011, 12:32 PM   #2
Old School
Willie T's Avatar
Butt the new board up against the corner bead, and then run up and down the corner bead with a hammer, tapping it down a little below the surface of both boards. Tape over that like it was just a regular joint.
The hammer tapping will usually flake off the thin layer of dried mud on the corner bead.
This is often preferable to tearing off the old corner bead due to the fact that you have no idea what is under that corner bead, (how much of a hidden, torn-up gap the original installer left), nor just what damage you may cause, yourself, getting the corner bead off.
Willie T
Old 09-25-2011, 12:41 PM   #3
take off the corner bead for a good smooth transition.
Marbledust is offline   Reply With Quote
Old 09-25-2011, 06:25 PM   #4
Too Old
x2 remove the bead
"Yeah, it's a nice garage, but you have to keep it heated at all times so it doesn't mess up your roof line."
havalife is offline   Reply With Quote
Metal corner bead vs Paper-Faced bead CMHbob Drywall & Plaster 6 04-09-2017 07:39 PM
Metal corner bead question Firehawk734 Drywall & Plaster 15 06-12-2011 02:49 PM
corner bead for drywall cfarmer Drywall & Plaster 2 04-13-2009 03:20 PM
Paper faced Metal inside/outside corners? slinku2020 Remodeling 6 03-20-2009 10:16 PM
corner bead on existing wall stallinc Building & Construction 12 01-30-2008 07:38 AM
