Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 11-17-2009, 03:21 AM   #1
Tape drywall joints before painting?
Hi, this is sort of painting question but also a drywall question. Just bought our first home, it's about 50 years old. We've started by removing all the wallpaper from one room. The drywall joints are not taped instead they are filled with what looks to be plaster of paris they seem hard and smoothe but if I don't tape them and cover them with joint compund before I seal/prime/paint will I get hairline cracks down the wall?
mcraenz is offline   Reply With Quote
Old 11-17-2009, 06:19 AM   #2
Remodeling Contractor
Drywall finishes are defined in 5 levels. Normally a person wants a level 4 for a good paint job. You are looking at a level 1 job. Yes.. tape the joints.
Old 11-17-2009, 07:45 AM   #3
Chicago, IL
Michael Thomas's Avatar
Thanks, Bob.... what I love about this board is that I learn something new and useful every day:
http://www.gypsum.org/pdf/GA-214-07.pdf
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs
Michael Thomas is offline   Reply With Quote
Old 11-17-2009, 09:26 PM   #4
Thanks for your replys. My concern is that the joints aren't recessed so if I tape them I'll get a hump in the wall. What if I just skimmed over them with joint compound so they are nice and smooth? It seems like the boards don't actually touch, there's about a 1/4" gap in between the boards which is filled with plaster of paris.
Old 11-17-2009, 10:02 PM   #5
Xtreme DIY'r
Are the joints cracked now ?
Old 11-17-2009, 10:11 PM   #6
They don't seem to be but I guess it might be hard to tell until I get paint on there where there could be movement, maybe some hairline cracks will stat to open up? I'm wondering is this plaster of paris jointing what they used before moren joint compound and tape. Maybe it's just wishful thinking but maybe since the paster is so hard maybe it won't crack the same as if joint compund had been used to fill the joint without tape?
Old 11-18-2009, 07:09 AM   #7
plaster never had joints and plaster cracks much more than drywall, which is why drywall is so widely used. You can float out the but joint to still get an appearance of a flat seam.
Old 11-19-2009, 07:28 PM   #8
Drywall contractor
They absolutely need tape to ensure they don't crack in the future. The wallpaper may have "acted" as tape to keep them from cracking. I really don't use the fiberglass mesh tape except for smaller repairs, but it does "lay" flatter than paper tape and may be an option to keep the joints from "rounding out" with paper tape. Use "setting" compound for, at least, the first coat though. Remember several thin applications are easier to deal with than "piling on" the mud to get it done quickly....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Tags
drywall, jointing, plaster, wallpaper
Repairing drywall tape bcouch Drywall & Plaster 2 09-08-2009 04:19 PM
painting new drywall in bathroom LittleBrownDog Drywall & Plaster 8 08-18-2009 07:53 PM
painting old unpainted drywall snsaction@aol.c Drywall & Plaster 1 07-29-2009 01:57 PM
Garage drywall painting haylo75 Painting 18 11-12-2007 09:13 PM
How to use non-adhesive drywall tape? tripower Building & Construction 1 05-28-2007 10:29 AM
