Subbing Out Drywall (maybe) - How Can I Make It Easier On Them? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-07-2011, 10:18 AM   #1
Subbing out drywall (maybe) - how can I make it easier on them?
I'm framing my basement myself, but I'm not sure I feel comfortable hanging the drywall. Is there something I can do to make the hanging process easier on whoever does it (in terms of how to start my framing corners)?
ctote is offline   Reply With Quote
Old 07-07-2011, 11:56 AM   #2
Next Time...New Build
Rewards Points: 150
Just make sure that your corners are fastened properly and each direction has the 1.5" of the 2x exposed. There is nothing worse than trying to screw your board into a spongy corner or not having enough meat to screw in to.
Another nice option is to take a long straight edge and put it along the finished framing to identify any high/low spots. Once identified you can plane/fur out any variances.
RickyBobby is offline   Reply With Quote
Old 07-07-2011, 11:59 AM   #3
What do you mean by "fastened"?
I was planning on just laying up Frame 1, screwing it up to the floor joists and the cement slab, and then doing the same with Frame 2 with the corners "touching" but not actually nailed/screwed together. Is that wrong?
Old 07-07-2011, 12:51 PM   #4
Rewards Points: 152
Beyond what will be the inside corner stud of wall 1, you will want blocking, so that when you put wall 2 in place, you can nail the end stud of wall 2 into it, in order to make your corner tight and straight.
Old 07-07-2011, 02:15 PM   #5
Rewards Points: 150
Double stud the corner on Frame 1, with the additional stud on the inside of the corner. A "backer" for Frame 2 if you will. That way you can nail Frame 2 to that, thus creating a nice tight corner.
Currently, there is no way to nail them together if the corners are just touching. By adding the backer you can secure it all together.
Old 07-07-2011, 02:18 PM   #6
Great, thank you!
In wall gutter downspout causing mold on drywall. chrispy35 General DIY Discussions 12 05-06-2011 10:35 PM
First-timer drywall install-LONG- Axhammer Drywall & Plaster 8 04-17-2011 09:02 AM
Skylights: New drywall meets popcorn ceiling. How to make look good? 211 Drywall & Plaster 2 01-11-2011 03:07 PM
Drywall over Drywall.. NoviceHandyman Drywall & Plaster 6 01-10-2011 08:32 PM
Ecorock (new green drywall product) Sir MixAlot Drywall & Plaster 0 06-20-2009 08:40 AM
