-   -   Subbing out drywall (maybe) - how can I make it easier on them? (http://www.diychatroom.com/f101/subbing-out-drywall-maybe-how-can-i-make-easier-them-109938/)
ctote 07-07-2011 11:18 AM
I'm framing my basement myself, but I'm not sure I feel comfortable hanging the drywall. Is there something I can do to make the hanging process easier on whoever does it (in terms of how to start my framing corners)?
RickyBobby 07-07-2011 12:56 PM
Just make sure that your corners are fastened properly and each direction has the 1.5" of the 2x exposed. There is nothing worse than trying to screw your board into a spongy corner or not having enough meat to screw in to.
Another nice option is to take a long straight edge and put it along the finished framing to identify any high/low spots. Once identified you can plane/fur out any variances.
ctote 07-07-2011 12:59 PM
What do you mean by "fastened"?
I was planning on just laying up Frame 1, screwing it up to the floor joists and the cement slab, and then doing the same with Frame 2 with the corners "touching" but not actually nailed/screwed together. Is that wrong?
DexterII 07-07-2011 01:51 PM
Beyond what will be the inside corner stud of wall 1, you will want blocking, so that when you put wall 2 in place, you can nail the end stud of wall 2 into it, in order to make your corner tight and straight.
RickyBobby 07-07-2011 03:15 PM
Double stud the corner on Frame 1, with the additional stud on the inside of the corner. A "backer" for Frame 2 if you will. That way you can nail Frame 2 to that, thus creating a nice tight corner.
Currently, there is no way to nail them together if the corners are just touching. By adding the backer you can secure it all together.
ctote 07-07-2011 03:18 PM
Great, thank you!
