Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 09-30-2012, 06:42 PM   #1
strapping / furring
Can 1/2" thick furring / strapping be used for securing drywall on a interior wall (not ceiling).
I am afraid it would split if I drive dry wall screw in it but nailing is fine?
I have 16" on center studs and want to secure the drywall every 24" on center instead.
Therefore I have to install 1/2" strapping / furring horizontally first and secured them to the 16" studs. Then my drywall screws can be anywhere on horizontally.
1/2" is the thickness I can go, will it split if I use screws or should I nail the drywall?
kingofmycastle is offline   Reply With Quote
Old 09-30-2012, 06:53 PM   #2
strapping / furring
why would you want to secure it every 24" and not just on the studs?
mae-ling is offline   Reply With Quote
Old 09-30-2012, 07:51 PM   #3
strapping / furring
Because the rigid insulation board from owen corning insulpink provides a channel 1" deep for strapping/furring but at every 24".
Old 10-01-2012, 07:16 PM   #4
retired union carpenter
Send a message via Yahoo to coupe
Question
strapping / furring
I"m lost, as to why you can only go 1/2"? this wont work in any way! #1- the thickness of the rigid board will determine the amount of wall thickness. #2- if the channel is 1" deep? and you only fill it with 1/2"? there is a 1/2" void, will make for a very wavy wall. something has to bend that 1/2" most likely the weakest point! the drywall paper, if you use any type of one direction grained furring strips? they'll likely split if you screw them? pulling the strips in that 1/2". = constant pressure on screw heads. as soon as they're properly sunk, will pop through the paper. if you try to nail? in center between studs? will be springy, each time you hit the nail, the gypsum inside will crack, each crack will separate the paper from gypsum. when you try to get nail dimpled for mudding, last hit will pull nail through the paper.
you're looking at every nail/screw popping soon, where not driven into the studs that are already there!
in my opinion, a lot of work putting up furring strips= absolutely no gain? only a lot of future problems.
good luck
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
The Hows and Whys of Furring Strips. Part-1 Willie T How To Guides 12 03-01-2013 03:58 PM
Furring strips for sheet rock miamicuse Carpentry 7 12-16-2011 07:22 PM
Furring strips on top of XPS? randall.miller Insulation 6 08-27-2011 08:39 PM
(Basement) Furring strips vs Traditional framing? ctote Carpentry 15 07-21-2011 01:00 PM
Floor bounce joist sistering joehomeowner Building & Construction 24 05-10-2009 02:50 PM
