Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 11-26-2011, 12:38 PM   #1
Strapping on ceiling, no header to screw into for walls
I am putting strapping on the ceiling and it looks like the ceiling will extend past the header once the sheetrock is up. There will not be any header left to screw the wall sheetrock to. I have studs 16 oc for the walls, will this suffice when screwing in the sheetrock where the ceiling meets the wall?
toobhed is offline   Reply With Quote
Old 11-26-2011, 01:00 PM   #2
Tileguy
Bud Cline's Avatar
What is "strapping" and where's the header? Yet another great close up photo but useless. How about a landscape photo?
Old 11-26-2011, 01:03 PM   #3
Tileguy
Bud Cline's Avatar
Okay wait I see.
Strapping is "hat channel" and header is "top plate".
So install some blocking between the studs to catch the drywall nails at the top, what's the big problem?
Old 11-26-2011, 02:50 PM   #4
Whats hard about that, hehehe, lotta extra work. :/
I am so close to drywall , i just want to get it done. If you were doing it on your own home, is this a must do step?
Old 11-26-2011, 03:12 PM   #5
Ironlight's Avatar
Anything that cuts down flexing and movement at joints is a good thing. It's going to be easier to put the blocks up now than it is to retape and sand every few years when cracks keep developing.
Ironlight is offline   Reply With Quote
Old 11-26-2011, 03:13 PM   #6
Tileguy
Bud Cline's Avatar
Then don't do it! Doesn't matter to me. You came here for advice, we didn't come looking for you.
If the drywall isn't backed up cracks could develop, but maybe not.
Old 11-26-2011, 06:20 PM   #7
Alright alright...just trying to gauge how important it is. Sometimes you get holmes on homes answers here when a guy might cut a corner doing his own house if it was not a big deal. I will just buck up and git er done.
Thanks for the advice!
Old 11-26-2011, 06:26 PM   #8
Home Remodeler
So what is hat channel?
mikey48 is offline   Reply With Quote
Old 11-26-2011, 06:30 PM   #9
Ironlight's Avatar
It has several uses, chief among them the hanging of ceiling tiles. I used it however to level out the ceiling in my kitchen/dining room when I pulled down the plaster and lathe ceiling.
Old 11-26-2011, 10:08 PM   #10
Tileguy
Bud Cline's Avatar
Every place I've ever been it has been called "Hat Chanel"...note the shape of the profile.
Mike Holmes and all of those ruffians he rode-in with are idiots when it comes to common sense approaches to remodeling!
Old 11-26-2011, 10:13 PM   #11
Disabled wood vet
titanoman's Avatar
No different than no nailer between the studs on the top edge of horizontally-run lower sheet. Code may say different.
titanoman is offline   Reply With Quote
Old 11-26-2011, 10:17 PM   #12
Tileguy
Bud Cline's Avatar
This is true if it weren't for the fact that this is at a "plane-change". On a flat wall all of the same plane blocking wouldn't be required but I think this is a different story.
Old 11-26-2011, 10:45 PM   #13
Disabled wood vet
titanoman's Avatar
Oh. I thought a wall just meets a ceiling w/no t/p or header to screw to. I didnt fully understand. I can't tell what I'm looking at in the picture.
Old 11-26-2011, 11:51 PM   #14
Moderator
4.6.4.1 Treated or untreated gypsum panel product joints oriented at right angles to wall or ceiling framing members need not be located over framing or other solid backing.
4.6.4.2 Gypsum panel product edges or ends, oriented at right angles to wall framing, that occur above ceilings when the gypsum panel product is terminated at less than the full height of the framing need not be located over framing or other solid backing. Page; 10, here: http://gypsum.org/pdf/GA-216-2010.html
The board has plenty of flexural strength, more/less depending on the orientation: http://docs.google.com/viewer?a=v&q=...U1o3kfoOlKl-7Q
Long as you are not playing baseball there……
Be sure to air seal the new drywall, required by code now if part of your thermal/air barrier.
If worried about cracks/movement, use paper tape rather than mesh.
Gary
Clothes taking longer to dry?
Old 01-07-2012, 03:14 PM   #15
Can someone explain to me why you would use hat channel? For flat surface for ceiling or sound isolation?
swarren is offline   Reply With Quote
Ceiling fan - Downrod won't screw in all the way tima2381 Electrical 8 05-02-2012 03:57 PM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 09:22 PM
Framing for Header in Basement Red Truck Remodeling 7 03-18-2010 09:11 PM
More Basement Dropped Ceiling Installation Questions markronz Remodeling 7 02-28-2010 04:47 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
