Strange Pattern On Ceiling Drywall - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-22-2009, 08:31 PM   #16
Rewards Points: 41
Had somebody come over and look at it - they felt it was condensation from thermal changes thru that area. I'll getting a 2nd opinion and will give an update.
kelley4180 is offline   Reply With Quote
Old 11-22-2009, 09:34 PM   #17
Registered User
Rewards Points: 5,492
That IS the second opinion, lol.
Be safe, Gary
Old 11-23-2009, 08:49 AM   #18
Household Handyman
Rewards Points: 1,408
I'm in agreement with termites, based on seeing these type "tracks" in homes I was called to about this type problem here in S. Ga. bjatlanta is correct in that taking a putty knife, laying it fairly flat to the surface and scraping off the remaining paper of the drywall should/probably will reveal termite tracks. As others have stated, termites will eat the paper backing of the drywall. I have seen results of them eating the paper, leaving the actual drywall and the paint. I also agree that if you are seeing these in your ceiling you probably have a larger infestation than you want, or you have drywall in your ceiling that those litlle critters like better than the walls. I do highly recommend calling in a reputable extermination company. Ask neighbors, friends, co-workers for recommendations. Good Luck, David
Old 11-23-2009, 01:24 PM   #19
If it is termites, eventually there will be some termite dust, similar to fine sand, falling out the tracks. If that hasn't happened yet, you might take a knife and cut open one of the tracks. If nothing falls out, you probably have don't have termites.
sluggermike is offline   Reply With Quote
Old 11-23-2009, 02:46 PM   #20
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
I believe this is one of the situations where a little research is called for. If it is termites and it is ignored believing it is a simple water stain, the termites could cause a lot of damage before realizing they are there.
On the other hand, should it turn out to be a water stain, you have a couple of touches of mud and some paint, which you already had to do anyway.
better safe than sorry.
Old 11-23-2009, 03:41 PM   #21
Registered User
Did any of you hold the "control" key while tapping the "+=" sign, 8 or 9 times on the picture? Knock-down texture, some finishers put black tint in the primer coat to get just that effect. "Control" and "-" key to remove.
Be safe, Gary
Old 11-23-2009, 04:13 PM   #22
Chicago, IL
Michael Thomas's Avatar
Not like any splash or knock downs I've seen:
http://www.drywallschool.com/textures.htm
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 10:05 AM
wet attic insulation and ceiling drywall rojas66 Drywall & Plaster 4 03-04-2009 03:33 PM
drywall for the ceiling genner Drywall & Plaster 8 01-11-2009 09:29 AM
Drywall Garage Ceiling Recommendations jsjames Building & Construction 6 08-22-2007 03:47 PM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 05:47 AM
