Strange Drywall Crack Pattern - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-14-2014, 12:57 PM   #1
Rewards Points: 58
Strange drywall crack pattern
Hello everyone,
This is my first post here. I noticed some hairline cracks around my master bath door on the second fl. Sorry for the bad quality pic. There are four fine cracks. Two major one are actually connected. I do have some other cracks on other doors/windows, but mostly are along the seams and straight up. This set of cracks puzzles me a lot. Thanks.
shiyang100 is offline   Reply With Quote
Old 01-14-2014, 01:26 PM   #2
Rewards Points: 14,312
Looks like normal settling cracks to me.
I thought this had been discussed before.
Old 01-14-2014, 01:34 PM   #3
Rewards Points: 6,034
The real pressure points, for lack of a better term, for drywall is the corners of doors and windows. The drywall has been cut, there is usually not much left between the top of the door and the ceiling. This is why you should not have a seam over a door or window. Take a door for instance how many times that door is opened and closed in say a year. And if you look when the door is opened wide you can usually see the hinge side move.
reoccuring drywall crack by window mmhendrie Drywall & Plaster 7 07-26-2010 02:47 PM
Is it normal to find 'strange' things when removing drywall? mikedavid00 Building & Construction 15 03-18-2010 10:49 PM
strange pattern on ceiling drywall kelley4180 Drywall & Plaster 21 11-23-2009 04:13 PM
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 09:42 PM
