Steel Studs And Sheetrock - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-13-2011, 09:07 AM   #1
Rewards Points: 12
Steel Studs and Sheetrock
I am finishing my basement and I have a partition wall framed that will separate the finished side from a non-finished side of the basement. The 20 gauge studs are fastened to the floor and joists (9 feet in height) and only one side of the wall will be covered with 5/8 in sheetrock. I was told I needed to add additional support to the framing because only one side will have sheetrock. Is this true and if so what do I need to do as additional support? Thanks
slamseven is offline   Reply With Quote
Old 03-13-2011, 09:56 AM   #2
one side is fine 16" on center, I would run a 1x4 horizontal stiffener midway on unfinished side
The older I get the better I was
The Following User Says Thank You to tpolk For This Useful Post:
slamseven (03-13-2011)
Old 03-13-2011, 10:43 AM   #3
Experienced
Jackofall1's Avatar
Welcome slamseven, to the best DIY'r site on the web.
Mark
Old 03-13-2011, 11:00 AM   #4
Rewards Points: 12
Thanks tpolk.
So just a 1x4 pine plank horizontally half way up the wall will do the trick?
Old 03-13-2011, 01:11 PM   #5
Rewards Points: 12
Thanks tpolk.
Old 03-15-2011, 03:32 PM   #6
Masters in Drywall
MnDrywallRanger's Avatar
Originally Posted by slamseven View Post
I am finishing my basement and I have a partition wall framed that will separate the finished side from a non-finished side of the basement. The 20 gauge studs are fastened to the floor and joists (9 feet in height) and only one side of the wall will be covered with 5/8 in sheetrock. I was told I needed to add additional support or a stiffener to the framing on the unfinished side because only one side will have sheetrock. Is this true and if so what do I need to do as additional support? Do I use wood or metal? How many? Etc., Thanks
You can criss cross a metal banding from an upper right corner to the bottom left corner and from the upper left corner to the bottom right corner and screw the strap to each stud along the way.
Another method would be to angle a couple perpendicular studs from the ceiling to the wall. This is used on backsides of walls and soffits in areas that aren't to be accessed.
MnDrywallRanger is offline   Reply With Quote
Old 03-15-2011, 10:53 PM   #7
Registered User
Rewards Points: 4,944
Welcome to the forum!
Please only ask and post the same question in one forum. Thank you.
Gary
Metal Studs for Ceiling? fivecitydjs Remodeling 14 08-06-2009 02:32 PM
Steel Studs Moisture problem bobdd Remodeling 21 06-29-2009 10:06 AM
Problen with hanging heavy draperies in sheetrock metal studs wall. Fixitgeorge Remodeling 1 04-11-2009 02:03 PM
Mounting a flatscreen TV on a sheetrock wall TanMan Building & Construction 14 02-16-2009 05:26 PM
Studs showing (bulging) through sheetrock js1971 Building & Construction 2 09-03-2008 07:48 AM
