Start With Walls Or Ceiling - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-10-2011, 11:34 PM   #16
msaeger's Avatar
Rewards Points: 260
Originally Posted by GBR in WA View Post
Drywall ceiling first as the walls will then support the ceiling's perimeter for less tape cracks from truss uplift-- called a "floating corner" here, (strapping is also covered): http://gypsum.org/pdf/GA-216-2010.html
Read all of these tips: http://www.finehomebuilding.com/PDF/Free/021174058.pdf
http://bestdrywall.com/files/ReduceCallbacks.pdf
Gary
I read the fine home building article and they show seams in between joists. Am I reading that right? I figured you wouldn't want an seam just floating between the joists.
msaeger is offline   Reply With Quote
Old 09-11-2011, 01:00 PM   #17
Old School
Willie T's Avatar
If you're talking about what is shown on Page 4, YES you do want to float the butt seam directly between two joists.
This is one of the latest advancements in drywall hanging (about 10 years old now) that enables you to now make butt joints without the nasty 'hump' we've fought for decades.
Willie T
Old 09-11-2011, 10:39 PM   #18
msaeger's Avatar
Rewards Points: 260
Thanks that is good to know. I figured I would have to get the edges of the sheets under a joist or stud. So I just have them in between two joists with nothing behind the seam right?
I suppose you really need to make sure all the joists are lined up or the edges of the two sheets won't be the same level.
Old 09-11-2011, 10:51 PM   #19
Old School
Willie T's Avatar
No, this conclusion is not correct at all ! Please go read Page 4 of the PDF. ALL of Page 4. (labeled #61)
You MUST use a Buttboard , and break as close to the center of the space between joists as you possibly can.
Otherwise do it the old way only....... break the joint on a joist.
Willie T
Old 09-11-2011, 11:41 PM   #20
Registered User
Rewards Points: 4,936
Good point....... I did a quick check of the UBC, IBC, and IRC- all require framing behind the end butt joints. http://nationalgypsum.com/products/..%5CFile%5C1046.pdf
Thought I read somewhere about solid blocking or backing there for a substitute, still looking.....
Anyone?
Gary
Old 09-12-2011, 11:06 AM   #21
msaeger's Avatar
Rewards Points: 260
When you say framing do you mean a stud or just a buttboard?
I found this page that talks about buttboards so I think I get what those are now.
http://www.finehomebuilding.com/how-...tt-joints.aspx
Old 09-12-2011, 11:28 PM   #22
Registered User
“All edges and ends of gypsum board shall occur on the framing members, except those edges and ends that are perpendicular to the framing members.”
http://publicecodes.citation.com/ico...002_par010.htm
That would include strapping or any material meeting the minimum required by Code. Not butt boards. Still checking.........
Gary
Old 09-13-2011, 11:24 PM   #23
Rewards Points: 374
You were asking about finding the outlet behind the drywall.
Here is a trick I saw done before.
Take a tube of lip stick. Run it around the edge of the outlet. Postion the board where it will be hung and press it again the outlet box.
there you have the box area marked, make sure it is the back of the dry wall. You can cut out the hole there or make a hole through the dry wall and then cut out once it is hung.
I just would not use a dark color of lipstick.
logluvr is offline   Reply With Quote
Old 09-15-2011, 09:50 PM   #24
Excellent tip
oscarmw is offline   Reply With Quote
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Ceiling Repairs and Muresco Paint: Seamless Paint Job Possible? Lovegasoline Painting 4 11-25-2009 03:06 PM
Sheetrock - walls before ceiling jhubert General DIY Discussions 2 12-29-2008 07:29 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
Bathroom Ceiling and Walls. Drywall ok? atilla137 Building & Construction 11 10-26-2006 04:32 PM
