Staggering Drywall Sheets - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-16-2012, 10:20 PM   #1
Rewards Points: 197
Staggering drywall sheets
If you are installing 4' x 8' sheets of drywall on a large ceiling area, is it a good idea to stagger the joints like you would when installing roof sheathing, or does it really matter with drywall ?
Arky
Arky217 is offline   Reply With Quote
Old 04-16-2012, 10:31 PM   #2
Arky
don't stagger. sheetrock is not a structural member. and it will make mudding/taping/sanding that much more annoying.
if it's a large ceiling, consider getting 10' or 12' long sheets.
wombosi is offline   Reply With Quote
Old 04-17-2012, 01:19 AM   #3
Registered User
Rewards Points: 4,924
You are required to stagger the end joints: 4.6.4 and 5.3: http://www.lafargenorthamerica.com/G...%20English.pdf
Check with your local Building Department.
You may be in a Seismic Zone: http://www.entergy-arkansas.com/cont...ing_Map_AR.pdf
They may require you to follow the prescriptive IRC Code: "End joints of adjacent courses of board shall not occur on the same joist." From: http://publicecodes.citation.com/ico...002_par012.htm
Gary
Last edited by Gary in WA; 06-13-2012 at 12:09 AM. Reason: Added drywall manu. link.
Old 04-17-2012, 06:19 AM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Its standard to always stagger sheetrock end-joints (butt joints), regardless whether its on a ceiling or wall.
Yes, you could go with larger sheets (than 4x8), just make sure that you have a 3rd helper.
(It is done with 2 men in the industry), but the average DIYer will need a 3rd pair of hands to screw off the sheet, while 2 are holding it up, or, you can try an use a DW lift, if you can find (or rent) one that will reach.
- Build Well -
Old 04-17-2012, 08:07 PM   #5
Rewards Points: 150
Arky
I always stagger and it is true the drywall adds no real "mechanical bond" strength to the joists by staggering joints. But joists are always flexing somewhat and when the tape joint is really long going down the same joist, the flex will be worsened on that joint possibly creating stress cracks in the tape joints. I been in and around construction for 40 years and have yet to see ceiling/wall drywall not staggered by pros. They must have a clue about something. jmo
Jeeps is offline   Reply With Quote
The Following User Says Thank You to Jeeps For This Useful Post:
kj6887 (04-18-2012)
Old 04-18-2012, 07:13 PM   #6
dogris's Avatar
After hanging a ceiling, I stagger around for the rest of the day
dogris is offline   Reply With Quote
Old 04-19-2012, 02:14 PM   #7
Mold!! Let's kill it!
Rewards Points: 2,012
As long as you aren't staggering before you start hanging the ceiling
Old 04-19-2012, 02:45 PM   #8
Drywall contractor
Rewards Points: 1,070
Absolutely stagger the joints and use the longest available board...
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
In wall gutter downspout causing mold on drywall. chrispy35 General DIY Discussions 12 05-06-2011 11:35 PM
Gap between sheets of drywall MikeKy55 Drywall & Plaster 21 04-05-2011 07:03 PM
Drywall sheets question kupalino Building & Construction 12 01-05-2010 07:35 AM
Large drywall patches - best way to fix? Screw them to what? Scott99999 Drywall & Plaster 6 11-19-2009 05:34 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
