-   -   Staggering drywall sheets (http://www.diychatroom.com/f101/staggering-drywall-sheets-140506/)
Arky217 04-16-2012 09:20 PM
If you are installing 4' x 8' sheets of drywall on a large ceiling area, is it a good idea to stagger the joints like you would when installing roof sheathing, or does it really matter with drywall ?
Arky
wombosi 04-16-2012 09:31 PM
Arky
don't stagger. sheetrock is not a structural member. and it will make mudding/taping/sanding that much more annoying.
if it's a large ceiling, consider getting 10' or 12' long sheets.
Gary in WA 04-17-2012 12:19 AM
You are required to stagger the end joints: 4.6.4 and 5.3: http://www.lafargenorthamerica.com/G...%20English.pdf
Check with your local Building Department.
You may be in a Seismic Zone: http://www.entergy-arkansas.com/cont...ing_Map_AR.pdf
They may require you to follow the prescriptive IRC Code: "End joints of adjacent courses of board shall not occur on the same joist." From: http://publicecodes.citation.com/ico...002_par012.htm
Gary
AtlanticWBConst. 04-17-2012 05:19 AM
Its standard to always stagger sheetrock end-joints (butt joints), regardless whether its on a ceiling or wall.
Yes, you could go with larger sheets (than 4x8), just make sure that you have a 3rd helper.
(It is done with 2 men in the industry), but the average DIYer will need a 3rd pair of hands to screw off the sheet, while 2 are holding it up, or, you can try an use a DW lift, if you can find (or rent) one that will reach.
Jeeps 04-17-2012 07:07 PM
Arky
I always stagger and it is true the drywall adds no real "mechanical bond" strength to the joists by staggering joints. But joists are always flexing somewhat and when the tape joint is really long going down the same joist, the flex will be worsened on that joint possibly creating stress cracks in the tape joints. I been in and around construction for 40 years and have yet to see ceiling/wall drywall not staggered by pros. They must have a clue about something. jmo
dogris 04-18-2012 06:13 PM
After hanging a ceiling, I stagger around for the rest of the day:jester:
Maintenance 6 04-19-2012 01:14 PM
As long as you aren't staggering before you start hanging the ceiling :thumbsup:
bjbatlanta 04-19-2012 01:45 PM
Absolutely stagger the joints and use the longest available board...
