Spraying Knockdown On Metal - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-02-2010, 11:51 AM   #1
Question
Spraying knockdown on metal
I'm doing my very first drywall finishing job in our garage and had a question. I'm going to do the entire garage in knockdown, since I'm not the best at smoothing things out right now.
We have a steel I-beam that runs across the width of our garage ceiling. Can knockdown be sprayed and finished on metal? We thought it might look good with the same texture as the rest of the ceiling and walls to help it blend in more.
Thanks,
Grant
granth77 is offline   Reply With Quote
Old 05-03-2010, 08:29 AM   #2
Drywall contractor
Rewards Points: 1,070
If the metal is clean it will stick for a while at least. Don't know how long it will last if you get radical temperature swings or have a lot of humidity....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 05-03-2010, 07:37 PM   #3
I was thinking that it probably shouldn't be done, but I just thought I'd check. Off to mask the beam!
Thanks!
Clearcoating a Stripped Vintage Ferrous Metal Medicine Cabinet? Lovegasoline Painting 15 08-31-2013 09:32 PM
condensation leak with metal roof on cathedral ceiling in Canada Serialrenovator Roofing/Siding 10 02-02-2010 12:18 AM
Problen with hanging heavy draperies in sheetrock metal studs wall. Fixitgeorge Remodeling 1 04-11-2009 01:03 PM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 08:46 PM
grounding pole building sheet metal? borderbuster Electrical 2 07-08-2007 02:11 AM
