Spray Texture To Match This Picture - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-20-2011, 09:21 AM   #1
Spray Texture to Match This Picture
Below is a pic of the spray texture I need to blend into a ceiling repair. I chose a wall shot to photograph because of the lighting, ceiling is the same.
I have a high CFM sprayer and hopper but due to limited experience, I would appreciate some input from more seasoned applicators as to the consistancy of the mud I should mix (thicker, normal, or thinner than pancake batter), plus nozzle choice (small, medium, large) and the air pressure that is most likely to spray this heavier than normal pattern. I will use a sheet of plastic hung on the wall to test the spray, but some expert suggestions up front would sure be great.
StuartT is offline   Reply With Quote
spray or brush baseboards? mathdan Painting 20 06-05-2015 09:41 PM
Skip Trowel Texture Briyon Drywall & Plaster 1 03-23-2011 10:20 AM
Looking for a kind of pest killer spray userid Pest Control 1 05-04-2010 07:06 AM
BIN Spray Shellac-Base Primer formulation PAINTLOVER Painting 0 05-01-2010 09:54 AM
Spray Texture Piney Painting 4 03-02-2007 12:24 PM
