Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 06-11-2011, 10:19 AM   #1
Spray Texture - Blending Old to New?
I removed a large built-in bookshelf from one of my LR walls. Behind the bookshelf was painted smoothwall, the rest of the wall is a heavy splat (not knock down) texture. I want to restore the wall to match the overall heavy texture in the room.
I have a hopper texture gun and compressor and some limited experience shooting texture. My question is do I have to scrape the old paint and texture off next to the smoothwall to get the whole wall panel smooth before I shoot? Or is it possible to feather sand the smooth/texture margin and blend in the texture when spraying? Never tried that before and don't want to attempt it if not possible to do a good job.
StuartT is offline   Reply With Quote
Old 06-11-2011, 10:33 AM   #2
the Musigician
DangerMouse's Avatar
Hi and welcome to the forum.
Do you have a photo you can post of the existing texture?
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 06-11-2011, 12:06 PM   #3
Let me see if I can get a decent shot of it and I'll post.
Old 06-11-2011, 12:30 PM   #4
Let's see if this works. Ah, good.
Old 06-11-2011, 07:47 PM   #5
General Contractor
It can be done, same as doing a patch in the middle of a wall.
I like to use a sanding sponge for the edges of the new mud. It helps get rid of the ridge that gets left since you aren't floating onto a flat surface. You'll likely be sanding some of the existing texture just around the "patch" in the process as well.....no biggie. Just be sure to get that ridge removed otherwise it'll show right through the new/blended texture.
dsconstructs is offline   Reply With Quote
The Following 2 Users Say Thank You to dsconstructs For This Useful Post:
DangerMouse (06-11-2011), StuartT (06-12-2011)
Some tips on matching spray wall texture - have a pic theedudenator Painting 1 01-08-2011 05:39 AM
Sand Texture in a Spray Can versus Textured Paint jweiner Remodeling 1 01-27-2009 05:29 PM
Blending ceiling patch with existing sheet-rock (slight texture) gmhut Painting 3 07-29-2008 12:16 PM
What to use to spray texture on new drywall? klemmy Remodeling 16 03-28-2007 07:14 PM
Spray Texture Piney Painting 4 03-02-2007 01:24 PM
