Spotting Screws - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-22-2010, 01:37 AM   #1
Spotting screws
What's the right way, when spotting screws in the field, as far as sanding goes?
I'm looking for a level 4 finish.
I'm expecting to coat each screw 3 times.
What grit sanding screen should I use and do you sand between each coat? What about the dust left behind after sanding?
Do you wipe down the field with a damp sponge or anything before applying the next coat?
Thanks, Ron
Ron Franck is offline   Reply With Quote
Old 01-22-2010, 03:05 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 396
100-120 grit, yes
yes
I can't get tapcon screws to tap into the concrete slab!? Monty Building & Construction 24 08-07-2010 07:08 AM
Stainless steel deck screws and hardibacker johnknez Building & Construction 1 10-09-2009 08:56 AM
New Drywall Installation, 1 joint screws are popping zjowens Drywall & Plaster 29 01-02-2009 12:26 AM
Screws vs Nails in Interior framing project alexz Building & Construction 2 07-05-2006 05:58 AM
