Special Saw For Clean Cuts In Drywall / Plaster - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-26-2009, 11:12 PM   #1
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Special saw for clean cuts in drywall / plaster
We are doing extensive electrical work (whole house rewire). There are areas that we need to cut out some drywall / plaster.
Are there any special saws that would help make nice straight cuts at the proper depth to make it easier to patch?
Jamie
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 01-26-2009, 11:32 PM   #2
K&B Remodeler/Tile Guy
angus242's Avatar
My 2 weapons for dealing with drywall are the jab saw and a rotozip. Jab saw is easy to control and you can keep dust to a minimum. Rotozip is a pretty clean cut but you can make one slip up and now you have more to patch than you bargained for. It's also VERY dusty.
Angus
My Albums
angus242 is offline   Reply With Quote
Old 01-27-2009, 07:09 AM   #3
Keep and old cordless trim saw around. They work great for this.
Josh Jaros
jaros bros. is offline   Reply With Quote
Old 01-27-2009, 11:45 AM   #4
Rewards Points: 26
Jamie, I have read that a 3-4 inch hole saw works good for clean holes and heard it's easy to patch. I have used these clips alot and they work great. You just cut a hole in between the studs and then put these clips in and screw the piece you cut out back in. http://www.prest-on.com/Scripts/prod...p?idcategory=3
ponch37300 is offline   Reply With Quote
Old 01-27-2009, 01:56 PM   #5
Remodeling Contractor
Hitachi made an electric drywall knife.. cannot get any cleaner than this. But a good electrician will not need to make too many holes. Patching the ones he does need will be easy with any of the tools already mentioned above.
Old 01-27-2009, 02:20 PM   #6
Oldguy
Rehabber's Avatar
Although a little expensive, a Multimaster does a great of precise cuts with little dust. It's also indispensable for many other remodeling jobs. A few companies are starting to make less expensive versions now that Multimasters patent has expired.
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 01-29-2009, 10:55 PM   #7
Tired & Dirty
Rewards Points: 83
I use a multi-master also, great tool, but blades are very painful to buy!
evapman is offline   Reply With Quote
Old 02-02-2009, 06:05 PM   #8
Drywall contractor
Rewards Points: 1,070
I do a lot of work repairing where electricians have to cut the drywall to run wires for adding can lights, etc. The easiest way I've found is for the electrician to use a 4" hole saw to cut the holes between the joists. I can cut "hot patches" all the same size. The 4" seems large enough to drill the joists and get a hand in to pull the wires.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
Plaster to drywall joint question. ERIK2173 Remodeling 7 05-16-2009 04:58 PM
Can you adhere drywall to plaster? whiskeykid Drywall & Plaster 9 08-15-2008 07:42 AM
Plaster and Lathe walls- covering with drywall Jrr1099 Building & Construction 4 03-24-2008 02:20 PM
Plaster on drywall? bofusmosby Carpentry 7 03-06-2008 07:30 AM
