Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 05-06-2011, 09:10 PM   #1
Spackling or Drywall Compound?
What would you choose in this situation?
About 1000 sq ft of wall with many nail holes, I am talking about hundreds.
Cost isn't a huge issue because I think they are closely priced.
Time required is most important.
Quality is not as important, it is in a room mostly not used.
Will prime and paint over it later.
Thanks!
peequi is offline   Reply With Quote
Old 05-06-2011, 11:03 PM   #2
Window and Door installer
Thanks!
Hundreds? In drywall? 20 or 30 minute mud prolly depending on how fast you are at spreading it. And you can spread it quickly with a large trowel.
What about texture?
Jkslate is offline   Reply With Quote
Old 05-07-2011, 02:54 AM   #3
yep, fast set mud, won't shrink as much
make sure you prime
chrisBC is offline   Reply With Quote
Old 05-09-2011, 08:57 PM   #4
Nail holes? Just regular All-Purpose or Finish mud, two coats. No need for anything else.
dberladyn is offline   Reply With Quote
Repair drywall paper before laying tile? amybeth25 Remodeling 4 08-29-2010 06:49 PM
painting new drywall in bathroom LittleBrownDog Drywall & Plaster 8 08-18-2009 07:53 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 04:49 PM
Re-doing Spackle mpedrummer Remodeling 4 08-12-2008 04:52 AM
Which drywall compound should I use? yummy mummy Building & Construction 16 11-12-2007 05:00 PM
