Spackling Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-04-2011, 02:43 PM   #1
spackling drywall
I just had my bath sheet rocked, do I need to tape over every drywall screw, or can I just spackle over the screws and tape the seams.
Pahabdul is offline   Reply With Quote
Old 03-04-2011, 02:49 PM   #2
Experienced
Jackofall1's Avatar
Welcome Pahabdul, to the best darn DIY'r site on the web.
Spakle over screws (make sure they are below the surface)
Tape over joints, inside corners, corner bead over outside corners.
Mark
Old 03-04-2011, 04:22 PM   #3
Handyman
Rewards Points: 512
Am I getting this wrong? Sheetrock for a tub surround?
canadaclub is offline   Reply With Quote
Old 03-07-2011, 01:36 PM   #4
JohnnyD44's Avatar
I would definetly spackle all of the nail holes and tape the way JackofAll described. I'm hoping if this is a tub surround or even if it's not that you went with the greenboard in your bathroom to help with humidity and water vapors. In either case I would patch all the nail holes
JohnnyD44 is offline   Reply With Quote
First-timer drywall install-LONG- Axhammer Drywall & Plaster 8 04-17-2011 09:02 AM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 09:30 AM
Is spackling paste the best to use on drywall? downrightart Drywall & Plaster 11 04-03-2010 03:41 AM
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 09:42 PM
