Spackling Compound - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 12-10-2011, 04:31 PM   #1
Spackling compound
Why does the spackling compound crack? What can be added to the compound to prevent cracks and shrinkage?
RN
RobbyN is offline   Reply With Quote
Old 12-10-2011, 04:43 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Spacking cracks when the hole being filled is too big. No big deal. Use it, let it dry, go over it if you have to.
Old 12-10-2011, 07:33 PM   #3
retired union carpenter
Send a message via Yahoo to coupe
Spackling compound cracks, because it's water based. anything with water will shrink as water dries out. it cracks more if coats are too thick! better to use more thin coats than try to fix with 1 or 2 thick coats adding more water, makes for smoother coating, but adds more water to need to dry out. I usually add about a quarter of water to a 5 gallon bucket and mix thoroughly.
as usual, my own thoughts
good luck
coupe
coupe is offline   Reply With Quote
Old 12-10-2011, 07:38 PM   #4
Rewards Points: 12,868
Spackling is made for filling small holes like there pictures were hung. If you trying to repair cracks in dry wall then you need to apply joint compound not spackel then dry wall tape then apply a thin coat of drywall compound over that once dry knock off the high places and apply more joint compound with a wider drywall knife. The last coat gets sanded and a really thin coat of drywall compound. Let try and lightly sand, prime then paint.
Spackling or Drywall Compound? peequi Drywall & Plaster 3 05-09-2011 08:57 PM
Joint Compound shaggy0125 Painting 8 01-12-2010 03:55 AM
Will joint compound stick to Zinsser 1-2-3? Lovegasoline Building & Construction 13 09-28-2009 11:55 AM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 06:50 PM
How to deal with setting drywall compound? KUIPORNG Remodeling 11 01-11-2007 09:22 AM
