Spackle Bubbles - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-06-2013, 08:35 AM   #1
Rewards Points: 874
Spackle bubbles
The guys are coming to finish the job today but i noticed in one or two areas there are bubbles in the spackle...some about 1/4" in diameter and some tiny. What causes this? Thans
Mstrlucky74 is offline   Reply With Quote
Old 04-06-2013, 08:46 AM   #2
Rewards Points: 13,690
It's drywall compound not spackle!
Any number if things can cause it.
Over working it, humidity to high ECT.
Happens to the best finishing job.
A light sanding or a thined finish coat of light weight compound will get rid of them.
Old 04-06-2013, 09:19 AM   #3
Rewards Points: 874
I will never say spackle again... Thanks a lot Joe... Much appreciated
Old 04-06-2013, 03:55 PM   #4
Rewards Points: 512
if you apply to much mud or when apply mud on a glossy surface the mud doesnt stick. the bubbles are easily fixed like what joecaption said by giving the area a thin quick coat over it. its nothing major and very easily fixable. happens to the best of us.
princelake is offline   Reply With Quote
Old 04-07-2013, 08:07 AM   #5
Rewards Points: 5,974
I might as well start the argument now. Put a squirt of dish soap in when mixing the mud=no bubbles.
Old 04-07-2013, 05:52 PM   #6
Rewards Points: 512
haha no argument with the soap. i never have bubble problems bad enough to do that trick but yes it does work
The Following User Says Thank You to princelake For This Useful Post:
ToolSeeker (04-07-2013)
Old 04-08-2013, 06:22 AM   #7
Rewards Points: 874
So don't use the compound right from the bucket? Mix it with a little water? Thanks.
Old 04-09-2013, 12:10 AM   #8
Rewards Points: 744
I find I usually need to mix a bit of water with the bucket mud.
And dish soap in your mud is not approved by USG. It can cause problems with the adhesive in the all-purpose mud and USG will not back it.
Seattle2k is offline   Reply With Quote
The Following User Says Thank You to Seattle2k For This Useful Post:
Nailbags (04-09-2013)
bubbles in new drywall mud gailquilter2 Drywall & Plaster 16 11-04-2012 06:40 AM
Putty or Spackle for stair rail and latex chip/peel repair. RickDel Painting 3 05-14-2012 10:12 PM
Millions of tiny bubbles John_W Plumbing 0 10-06-2011 10:10 AM
bubbles in tape BlueBSH Drywall & Plaster 1 11-05-2010 11:20 AM
Re-doing Spackle mpedrummer Remodeling 4 08-12-2008 03:52 AM
