-   -   Spackle bubbles (http://www.diychatroom.com/f101/spackle-bubbles-176410/)
Mstrlucky74 04-06-2013 08:35 AM
Spackle bubbles
265 Attachment(s)
The guys are coming to finish the job today but i noticed in one or two areas there are bubbles in the spackle...some about 1/4" in diameter and some tiny. What causes this? Thans
joecaption 04-06-2013 08:46 AM
It's drywall compound not spackle!
Any number if things can cause it.
Over working it, humidity to high ECT.
Happens to the best finishing job.
A light sanding or a thined finish coat of light weight compound will get rid of them.
Mstrlucky74 04-06-2013 09:19 AM
265 Attachment(s)
I will never say spackle again.:yes:.. Thanks a lot Joe... Much appreciated
princelake 04-06-2013 03:55 PM
if you apply to much mud or when apply mud on a glossy surface the mud doesnt stick. the bubbles are easily fixed like what joecaption said by giving the area a thin quick coat over it. its nothing major and very easily fixable. happens to the best of us.
ToolSeeker 04-07-2013 08:07 AM
I might as well start the argument now. Put a squirt of dish soap in when mixing the mud=no bubbles.
princelake 04-07-2013 05:52 PM
haha no argument with the soap. i never have bubble problems bad enough to do that trick but yes it does work
Mstrlucky74 04-08-2013 06:22 AM
265 Attachment(s)
So don't use the compound right from the bucket? Mix it with a little water? Thanks.
Seattle2k 04-09-2013 12:10 AM
I find I usually need to mix a bit of water with the bucket mud.
And dish soap in your mud is not approved by USG. It can cause problems with the adhesive in the all-purpose mud and USG will not back it.
