Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 05-28-2012, 09:36 AM   #1
spackle
There was an old cup holder glued inside a nice formica cabinet door. It wouldn't come off so I pounded on it and it came off.
Also an amazingly large section and layer of the inside door came off with it and it looks bad. Is spackle what I need to buy? Then I'll repaint the door.
thank you
Startingover is offline   Reply With Quote
Old 05-28-2012, 09:58 AM   #2
spackle
I would use this instead.
http://www.waterputty.com/
Less likly to crack as it drys since it's a thick layer, drys hard as wood, sands great.
Old 05-28-2012, 10:52 PM   #3
spackle
thank you Joe!
Old 06-01-2012, 06:14 PM   #4
Drywall contractor
spackle
The stuff is great! I've been using it since the mid 70's. HD carries it, Lowes may too. There's a reason they call it "rock hard". Not the easiest to sand, so don't apply too heavy a coat. A couple of thinner coats are easier to deal with.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
The Following User Says Thank You to bjbatlanta For This Useful Post:
Startingover (06-01-2012)
Old 06-01-2012, 11:56 PM   #5
spackle
just bought it today at Lowes. Am anxious to try it. I'll let you know if a novice finds it decent to work with.
Putty or Spackle for stair rail and latex chip/peel repair. RickDel Painting 3 05-14-2012 11:12 PM
Wall/Paint and Spackle Spots I will try to make this short... cluelessathome Painting 8 11-29-2010 11:30 AM
Quick & Dirty Trim Salvage: Spackle to fill Old Chipped Paint? Lovegasoline Painting 10 12-17-2009 04:34 AM
Re-doing Spackle mpedrummer Remodeling 4 08-12-2008 04:52 AM
spackle cold temperatures farrington135 Building & Construction 2 01-19-2007 04:48 PM
