Solution For 8" Gap From Floor To Edge Of Drywall. - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-25-2013, 09:13 PM   #1
Solution for 8" gap from floor to edge of drywall.
Need some ideas on finishing an 7" gap i purposely left from floor to edge of rock for accessibility to steam return pipe in my basement project. My line of thought was to just nail 8" molding into the frame in case i had to get to the return pipe for some reason in the future (my idea was it's easier to just remove the molding rather than breaking through rock and have to repair). The problem now is, i can't find any molding that wide (I know should've checked before going through with plan). I attached a picture of the area in question. My current idea is to get 1x8 boards, rout the top edge and use my finishing nailer to nail it to the frame, but wanted to get a consensus from the pros.
Solution for 8" gap from floor to edge of drywall.-img_20130323_131743_315.jpg
GeorgeNS is offline   Reply With Quote
Old 03-25-2013, 09:44 PM   #2
Rewards Points: 986
Why not?
Last month I was horrified by the price of molding, so I made my own. Naturally it helps if you are willing to use a simple profile.
Toller is offline   Reply With Quote
The Following User Says Thank You to Toller For This Useful Post:
GeorgeNS (03-25-2013)
Old 03-25-2013, 09:57 PM   #3
was thinking of going with something like this with the 1x8, some bullnose at the base.
Old 03-26-2013, 05:37 AM   #4
Rewards Points: 13,950
No way would I have done it that way but what's done is done.
Main reason is air leaks.
Going to have to add 1/2 shims to all the studs now, insulate those pipes before covering or they may cause condinsation.
Add your 1 X 8's then use base cap moulding.
http://www.tiloindustries.com/profil..._profiles.html
Install your 1 X 8's
I would perprime and paint the trim on all sides.
No insulation or vaper barrier behind that sheetrock?
GeorgeNS (03-26-2013)
Old 03-26-2013, 07:08 AM   #5
I agree Joe, in hindsight I definitely should've gone a different route and there's definitely cold air flowing from that area most likely due to the concrete basement wall that's exposed. I just didn't want to go through the nightmare of tearing up the sheet rock and redoing if Murphy came around and I needed to get to the return pipe. Also, the pipe get's pretty hot when the boiler is running and was thinking it would double as a heating source for that small room (the actual steam pipe is in the soffit above and has a section with radiator fins to actually heat up the room as well). I'll post some pics once the Mcguyver fix is done. You live and learn right?
Old 03-31-2013, 09:03 PM   #6
And here it is. Almost done
Old 04-01-2013, 12:10 AM   #7
Rewards Points: 626
Give yourself a huge pat on the back! it looks great! you better be proud of yourself on that job
Nailbags is offline   Reply With Quote
The Following 2 Users Say Thank You to Nailbags For This Useful Post:
GeorgeNS (04-01-2013), ToolSeeker (04-01-2013)
repairing drywall around shower stall gogreenwave Drywall & Plaster 3 02-18-2013 10:18 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 01:12 PM
Shingle Installation with F5S Standard Drip Edge ShortEdged Roofing/Siding 32 02-15-2008 02:10 PM
J-channel on drywall edge, do I glue or just put in place yummy mummy Building & Construction 14 01-29-2008 04:10 PM
