Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 04-14-2011, 12:16 PM   #1
Soffit in Basement
For the ceiling portion of a basement soffit... What's a good rule for thickness of drywall and length of unsupported span? Like 1/2" is good for 16", 5/8" for 24"...
Just trying to balance framing needs vs ceiling height under the soffits.
Shaotzu is offline   Reply With Quote
Old 04-14-2011, 07:13 PM   #2
MikeKy55's Avatar
Soffit in Basement
You will likely get more ideas/opinions here, but on mine I did 24 OC below the soffit and used 5/8ths rock. Also ran the 2X4's flat across so as to maintain as much height as I could. My soffit is about 6 feet across, so I ran a 2X4 along on top of the cross pieces and a vertical 2X up to the joist above the duct work. I did pull ups on every one of them and nothing moved. I weigh 195lbs. The insulation looking material is Roxul safe-n-sound sound deadener.
MikeKy55 is offline   Reply With Quote
The Following User Says Thank You to MikeKy55 For This Useful Post:
Shaotzu (04-16-2011)
Old 04-14-2011, 07:19 PM   #3
Moderator
Soffit in Basement
Follow the tables; http://gypsum.org/pdf/GA-216-2010.html
Gary
Clothes taking longer to dry?
The Following User Says Thank You to Gary in WA For This Useful Post:
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 09:51 PM
Basement Remodeling - Soffit Question Mango Remodeling 7 11-22-2008 04:02 PM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 10:09 AM
soffit in basement DIY4EVER Building & Construction 2 06-18-2007 10:05 AM
Another Ridge Vent, Gable vent and soffit question (??) davco Roofing 2 05-01-2007 12:14 AM
