Small Drywall Repair And Texture - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 10-16-2009, 02:14 PM   #1
Rewards Points: 62
Small Drywall Repair and Texture
I am preparing my home for sale and the first thing I want to do is paint. I have a few corners that over the years the kid or the dog or furniture ran into and chipped of the drywall and texture and you can see the metal corners. Im pretty sure I can buy the patch made up and apply a few coats and sand it down and do that part but Im not sure about matching the texture. I don't think it will ever be exact but I just want it to not stick out like a sore thumb. I was thinking about buying some of the canned texture at Home Depot and see how it goes with that. Im lucky because the areas are pretty small. The other problem is that there is some hairline cracks on the corners. Dont really know how to handle those but thinking maybe just some paint will push them down tight? When I first moved in the house settled and there were a few of those metal corners that long cracks in them and if I remember right a handyman came in and put screws in them somehow and then respackled over them and retextured. Does that sound logial? Any help is appreciated as I am going to try to attach some pictures. Thanks.
DH
http://www.franceschi.com/Corner1.jpg
http://www.franceschi.com/Corner2.jpg
http://www.franceschi.com/crack-line-on-corner.jpg
http://www.franceschi.com/Crackline.jpg
DoubleHumbucker is offline   Reply With Quote
Old 10-17-2009, 03:35 PM   #2
i can't quite tell but that looks like regular orange peel or knockdown. the cans at HD should be fine.
djrussell is offline   Reply With Quote
Old 10-17-2009, 03:59 PM   #3
Rewards Points: 62
Thanks I will give that a try.
DH
Old 10-17-2009, 04:06 PM   #4
Residential Contractor
Try it on a piece of cardboard first.
rselectric1 is offline   Reply With Quote
Old 10-17-2009, 04:14 PM   #5
Residential Remodeler
Or a leftover/scrap of drywall...
CookeCarpentry is offline   Reply With Quote
Old 10-17-2009, 04:18 PM   #6
Drywall contractor
Rewards Points: 1,070
Looks like knockdown. The small cracks, I would try taking a screwdriver or painters 5 in 1 tool and "vee" out the crack a bit. Caulk with latex, touch up the texture, and paint. If you go to nailing/screwing the bead back down, it may just continue to crack further up or down. The latex is more flexible/forgiving than joint compound for minor problems. The "dings" where a chunk of mud is knocked off the bead will require joint compound. Scrape/sand around the area, apply mud (2 coats), texture and paint.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
primer not adhering to drywall texture? eli_carson Drywall & Plaster 13 07-25-2013 08:00 AM
How to repair textured drywall? Viper16 Drywall & Plaster 2 10-16-2009 12:13 PM
Texture Coming off Drywall Ceiling Pil Painting 9 03-12-2008 06:34 PM
Drywall texture matching budking Painting 3 10-29-2007 02:38 PM
several problems while texture painting ceilings and walls carrotguy Painting 2 05-25-2007 03:38 PM
