Small Baseboard Against Tapered Edge - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-14-2010, 12:22 PM   #1
Rewards Points: 270
small baseboard against tapered edge
hi - hope this isn't a dumb question - i drywalled my living room area using horizontal sheets. top edge will butt against a t&g or some kind of bead-board ceiling so i'll likely have some kind of wood trim there. Bottom edge will have a regular baseboard finish.
since the bottom edge is tapered (I didn't mud it) what happends if the baseboard I'm planning on using is fairly short (e.g. 3 -1/4 ")? setting the back of the baseboard against a tapered surface - won't that make it go kinda wonky?
sort of the same question on the top edge - if I use a narrow trim piece that does not cover the width of the tapered drywall edge - will not look right?
do the pro's mud the top /bottom edges, or do you just plan on using larger stock to trim top and bottom finishes on horizontal drywall runs to cover the tapered edges?
rtoni is offline   Reply With Quote
Old 05-14-2010, 02:25 PM   #2
Drywall contractor
Rewards Points: 1,070
The tapered edge is about 2-5/8" and standard base is 3-1/4" , both should be off the floor approx. 1/2", so it shouldn't matter. If you go with a narrower base, you should fill the taper or you will be able to see the transition at the taper. When finishing for a grid ceiling I usually fill the taper at the top for just that reason so I can keep the wall mold as high as possible without the taper showing. Any crown mold over 2-3/4" will cover. Smaller, and it will need to be filled.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 05-14-2010, 02:53 PM   #3
Rewards Points: 270
thanks BJB - just thinking - even if I used a taller baseboard what would happen if I shoot nails into the tapered area - the board would cover, but would it pull the bottom into the taper - at the same time leaving a bit of a gab along the top edge of the baseboard?
I got a feeling I have a bit more work to do
Old 05-14-2010, 04:58 PM   #4
Drywall contractor
As long as the top of the base is above the taper, you won't have a problem. The top needs to be caulked anyway if you're painting. I have never had to fill the bottom taper that I can recall (I do trim also).
Old 05-17-2010, 10:07 AM   #5
Rewards Points: 270
thanks bjb - appreciate the advice...
Can a DIY build a small in-ground swimming pool? zel General DIY Discussions 14 06-15-2013 10:42 AM
Ice and Water Shield under drip edge? sutterml Roofing/Siding 10 07-11-2011 06:04 AM
How to transition from door casing to baseboard? RxScram Carpentry 12 11-14-2009 12:10 AM
Best way to waterproof fascia when roof lacks a drip edge? Studly Roofing/Siding 4 10-07-2009 11:49 AM
Roll Roofing Edge Leak toolboxone Roofing/Siding 5 10-07-2009 07:09 AM
