Slightly Recessed Drywall Patch - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-17-2013, 08:01 PM   #1
ARB
Rewards Points: 99
Slightly recessed drywall patch
I'm doing a large drywall patch in my ceiling, and due to the uneveness in the ceiling, there are some places where the patch is slightly recessed, perhaps 1/16" or 3/32", as compared to the existing ceiling adjacent to the patch. (Yes, I used shims in some places, but this was about the best I could get it )
Anyway, I was thinking about filling the recesses of the patch with mud and letting it set, prior to taping. This would eliminate the "step" along the edges of the patch and ensure that the tape lays completely flat. Does this sound like a sensible idea, or is this not a big deal and I'm being overcautious? Is it OK to tape over a thin layer of dried mud?
Thanks!
ARB is offline   Reply With Quote
Old 03-17-2013, 08:52 PM   #2
Rewards Points: 6,652
How large is this patch that we are talking about? This is the reason that Popcorn ceilings were invented, to hide the imperfections.
As for fixing it, you could with Hot mud, but it can also turn into a disaster, after this disaster.
Old 03-17-2013, 09:50 PM   #3
Rewards Points: 512
ya do a "prefill" before taping so when the tape goes on it close to flat. or just tape it and skim it. either way would work
princelake is offline   Reply With Quote
Old 03-17-2013, 10:58 PM   #4
Or cut a piece of gypsum larger than the patch, cut off some of the backing material and gypsum off the front paper, then use that as your patch. Only works for small holes up to 8 inches, anything larger, you may as well cut back to the studs, add a couple of pieces across the hole, to help secure the patch. Shimming can be done with some ripped wood stock if you have a table saw, or go to some place like Lowe's, Home Depot, and they will either have in stock, or will rip a 2x piece of stock to your spec's for the shims, then just go from there.
I have gone as far as use old wood paint stirrers, run some hot glue along it, attach the patch, then mud, lay the flaps back on the mud, mud over the flaps of the patch, let dry, then sand, apply more mud, let dry, sand, check for any imperfections, lay another coat if needed, then sand, prime, paint.
Old 03-17-2013, 10:59 PM   #5
ARB
Rewards Points: 99
OK, great, thanks!
4 feet by 2 feet
you could [fix it] with Hot mud, but it can also turn into a disaster, after this disaster.
Greg, is there something about this I should be concerned about or particularly careful about?
Old 03-17-2013, 11:30 PM   #6
That is a large patch, so you are talking about the fact, that valleys and high spots will show up more, especially on ceilings. As for using Hot mud, you make as much as you can work with, due to it will set pretty fast if you are slow about applying it. That is why you see professionals use long knifes that can apply a large section of mud at a time, but they also have done this stuff for a long time, so they are able to fix issues if you get someone that knows what they are doing.
You may have to scrape off what you have, pull the patch, and then fix it with another shim, then lay a six foot level across it to check for flush.
Old 03-18-2013, 09:00 PM   #7
Rewards Points: 512
i've tried doing the california patch a few times and they never turn out great. i've always had better success just put a backer and putting tape on it and skimming
Old 03-19-2013, 09:00 AM   #8
ARB
Rewards Points: 99
Hey Greg, thanks for all the info; I appreciate it. I was taking another look at the patch last night (which has been screwed in but not taped/mudded), and my leaning is to give it a go as is... The uneveness is only in spots and it's literally not much more than 1/16" of an inch at its worst. Does that sound reasonable?
Drywall patch strong enough to hold an anchor? kevind Drywall & Plaster 4 02-08-2013 09:51 AM
My window between siding and drywall... jamieofansa Drywall & Plaster 2 09-05-2010 09:55 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 10:30 AM
Texturing drywall patch? Doug Crf Remodeling 4 09-21-2006 08:54 PM
I hope I don't have to tear down the ceiling brds16 Carpentry 9 04-30-2005 11:16 AM
