Skylights: New Drywall Meets Popcorn Ceiling. How To Make Look Good? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-11-2011, 02:12 PM   #1
211
Rewards Points: 49
Skylights: New drywall meets popcorn ceiling. How to make look good?
I put new skylights in the livingroom and need to transition the new drywall in the wells to a popcorn ceiling.
I'm looking for some advice to make this look as clean as possible.
Obviously the popcorn is what it is and I have no intentions of scraping it anytime soon (that's another post). The other thing is, I framed in the wells so they're flared to allow more light, that means I can't just take some outside corner trim and go around the perimeter because the ceiling-to-well corner is not 90* it's more like 15* on the top and 45* on the bottom. Of course the sides are 90 because of the rafters...
211 is offline   Reply With Quote
Old 01-11-2011, 02:36 PM   #2
Experienced
Jackofall1's Avatar
Make a pattern of the angles, go to a local sheet metal shop and see if the can bend you some stainless or just metal that you can fasten and paint.
Old 01-11-2011, 03:07 PM   #3
The most simple way would be to run your casing so that it actually over hangs into the window well by 1/4" to a 1/2" and finish wall down to it. Nobody should be able to see above the casing.
If you don't like the look of that you can do more by.
Putting L metal with splay metal as a possibility. Putting it on the bottom of the sheetrock, finishing it of course, and then going over the bottom of the skylight ceiling with casing.
redmanblackdog is offline   Reply With Quote
Nailing ceiling drywall good or bad KarlJay Drywall & Plaster 5 10-18-2010 11:39 PM
Basement drywall ceiling and walls questions enero Drywall & Plaster 6 06-05-2010 03:13 PM
Drywall Corner and Ceiling Skim Coat Rbchound Drywall & Plaster 6 04-29-2010 10:59 AM
Insulating a Perfectly Good Ceiling Creekbender Building & Construction 2 03-02-2010 06:55 AM
drywall for vaulted ceiling mdudu Roofing/Siding 5 03-02-2010 12:24 AM
