Is This A Skip Trowel Texture? (picture) I Need To Recreate It - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 12-21-2012, 10:01 AM   #1
langless28's Avatar
Rewards Points: 152
is this a skip trowel texture? (picture) i need to recreate it
i has to remove a part of my cathedral ceiling (bottom part of picture is new drywall) to add a french door and i have this texture all over the ceiling. how can i go about recreating it? i was just going to "wing" it with a trowel and try to get something close. also, can this texture be repainted?
langless28 is offline   Reply With Quote
Old 12-21-2012, 10:29 AM   #2
Rewards Points: 13,748
Looks more like some DIY just winged it.
http://www.drywallschool.com/textures.htm
Old 12-22-2012, 09:24 PM   #3
automated tool pro
Rewards Points: 152
roll a watered down joint compound over the new area, take a four inch paint brush creating stroke marks...make it busy. let it sit for a few minutes, time is important. after sitting for a little bit, test a spot with a 8" drywall knife..a short plastic handled knife...not a long wooden handled knife for this.
press a very very very slight arch into one side of the knife...this helps eliminate edges
time to float over the top of the still wet and waiting ceiling
the pattern in the picture was done exactly in this fashion, good luck
it could have been a trowel...same concept
drywallfinisher is offline   Reply With Quote
Another Wall Texture Question angelatc Drywall & Plaster 4 11-10-2012 07:29 PM
Spray Texture to Match This Picture StuartT Drywall & Plaster 0 07-20-2011 09:21 AM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 09:30 AM
several problems while texture painting ceilings and walls carrotguy Painting 2 05-25-2007 03:38 PM
Repairing dry wall and matching texture? Doug Crf Building & Construction 1 08-17-2006 03:50 PM
