Skip Trowel Texture - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-22-2011, 12:22 PM   #1
Skip Trowel Texture
I hope I am posting this in the right area...
We recently had some water damage to the drywall in our townhouse in AZ. The water removal and restoration folks took out about 2 feet of drywall and insulation from the floor up. I am going to replace the drywall myself and have a question about matching skip trowel texturing. The walls are currently textured using the skip trowel method. My question is...how do I treat the transition area from the new drywall patch to the existing drywall with the texturing. Should I randomly sand areas at that seam and then apply the texture? Is the texture used for this purpose? To hide defects or changes in the sheet rock? I personally am not a big fan of the texture but it is throughout the house so I think my only option is to try and match it. Any help, tips, expert advice would be greatly appreciated. I have watched a couple of videos on applying the texture and it looks pretty straight forward. The information that is missing is things like
1) Type of mud to use and the consistency.
2) How to deal with patches
Thanks,
Brian
Briyon is offline   Reply With Quote
Old 03-23-2011, 10:20 AM   #2
Without pictures or being there myself, I can only guess what you really have. All journeymen have there own little tricks, and likes and dislikes(thousand ways to skin a cat). Myself I usually use mud straight out of the box, no mixing. They make mud looser now than they did 20 years ago. They must have realized that water is cheaper than material, kind of like processed ham. However if you get an older box of mud, sometimes the extended shell life will dry the mud a little so on occasions you may need to mix water with it. If you can, use 80 grit sand paper and try to sand through the paint to the existing texture and sand the texture down at least 12"s from the patch. But be carefull not to over sand and get into the face paper of the drywall. It doesn't have to be perfect but you want to minimize the build up of mud if you can. However heavier textures do hide a lot more of the inconsistencies. Once you have that prepped then you prefill any larger cracks, and put the tape to it. You then need to put a couple of coats of mud on each side of the tape to help hide the hump the tape will usually cause. I use an 8" knife on the second coat and a 12" on the finish coat, always trying to feather the edge. Sand it down and touch it up, and start trying to match the texture. The good thing here is that if you don't like what you've done you just scrap it back off before it drys and try again. I usually use all purpose (beadex) when I do hand texturing. Drywall mud is water soluable, so once you have finished texturing and it has dried, you can take a wet rag and wipe off any texture that might not be in the location that you want it(like new texture laying on the old texture, if it does not look right. A wet rag can also wipe out any heavy edges or ridges caused by trying to work the mud in the existing textured areas. Good luck, have some fun.
redmanblackdog is offline   Reply With Quote
primer not adhering to drywall texture? eli_carson Drywall & Plaster 13 07-25-2013 08:00 AM
How to achieve this stucco texture? --pix inside... Kooter Building & Construction 2 08-26-2008 06:24 AM
Smoothing out skip troweled wall texture wem Remodeling 2 03-03-2008 11:57 AM
Whats the best way to remove orange peel wall texture? billyg Carpentry 2 01-30-2008 04:09 PM
several problems while texture painting ceilings and walls carrotguy Painting 2 05-25-2007 03:38 PM
