Skinning A Drywalled Wall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-09-2011, 05:20 PM   #1
Skinning a drywalled wall
My wife saw in a local business what appeared to be a skinned concrete (thinset or cement?)wall over drywall - providing the illusion of an industrial modern vibe. I went over to the business yesterday and noticed
a. Its a smooth finish
b. Appeared to be troweled on - imperfections in finish
I now have no ideal how to do this. I have seen external buildings use this with chicken wire - But to apply to an interior drywall that has primer and paint... Lost/...
Any suggestions or experience with this?
Thanks -
rickh is offline   Reply With Quote
Old 03-09-2011, 05:31 PM   #2
DIY staff
Rewards Points: 7,174
Did you take a picture? There are a couple of drywall pros here that might be able to offer a solution--
---Mike---
Old 03-09-2011, 05:56 PM   #3
Skinning a Drywalled wall
I sure did - for some reason the attachments are not working. See this link.
http://gallery.me.com/rickhskx#100102
Old 03-09-2011, 07:30 PM   #4
DIY staff
Very interesting look-----I wonder if a plasterer added some kind of top coat---
Some one must have seen this before---
You might ask the shop owner---Mike---
rickh (03-14-2011)
Old 03-14-2011, 12:42 PM   #5
Hello All,
Any suggestions? I can reshoot a pic where the drywall meets the external coat if it helps.
Old 03-14-2011, 08:21 PM   #6
Rewards Points: 282
it almost certainly is not cement (that would fail due to flex, joints, etc).
it is probably just a plaster rough skin coat and a faux finish..possibly the ralph lauren suede or similar.
jcrack_corn is offline   Reply With Quote
Old 03-14-2011, 09:34 PM   #7
That looks like Venetian Plaster to me tinted to a cement grey color. If your not familiar, its tinted plaster thats smooth or sometimes has a fine aggregate depending on the desired texture. It's trowled on in multiple coats, then burnished to a satin like finish or waxed for a glossy finish. This is the product I've used. It's arguably the best plaster you can buy, a little pricey, but worth it. http://www.vero-rialto.com/. Behr has a venetian at Depot, if your on a budget and want to take your chances. Good Luck.
SoCalLivin is offline   Reply With Quote
Old 03-16-2011, 09:27 AM   #8
I appreciate the advise. I will look into this plaster. Thanks again.
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
building a wall against an exterior wall Mike L General DIY Discussions 2 08-20-2009 02:50 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
