-   -   skimming a rough old plaster wall primed (http://www.diychatroom.com/f101/skimming-rough-old-plaster-wall-primed-170574/)
deck hand 01-30-2013 01:38 PM
I have removed the wall paper,
the walls are old wet plastered ( rough ) like Oh Boy! :censored: But they have been primed,
I plan on painting the lower half and papering the upper section
I need to skim the lower half to get a better smoother look.I want to add picture frame molding wainscoting
I want to skim coat the lower half But the question is will the Joint Compound stick to the primer ? if so after I skim coat I will need to prime again right ?
I plan on satin finish so show less roughness.
What's the Verdict
Deck Hand
chrisn 01-30-2013 05:00 PM
yes and yes
ToolSeeker 01-30-2013 05:29 PM
yes and yes.
deck hand 01-30-2013 06:50 PM
Originally Posted by ToolSeeker (Post 1105879)
yes and yes.
ToolSeeker and Chrisn
Thank You. Thank you,
Tomorrow I plan on shopping for a Five Gal. pail of JC
some tools and then Do it to it.
I'm 74 years old when I was 12 I worked with an Italian Master Plasterer,
I was his go for kid. I wished I had learned his trade.
Thanks again
Deck hand
deck hand 02-01-2013 08:16 PM
skimming that old wall ( continued )
Hi Plaster Buddies
Well I just wanted to let you all know I was successful in my attempt of skimming my first wall. My second coat is drying now. looks very nice, some sanding here and there. It took me a while to figure I was to light handed with my trowel leaving voids and skips trying to repair goofs, soon I got the knack To where I knew I would fix any errors on my second layer.
Thanks to the many youtube lessons too.
Deck hand
Now the next big job is the flooring then new railings.
funfool 02-01-2013 09:23 PM
glad you got it, That first coat is always just a filler and looks bad.
Second coat is much smoother, and then the 3rd really makes it smooth.
I have had a few rough plaster texture jobs, they want a smooth no texture finish, has taken 4 coats.
But each coat gets smoother as you go.
deck hand 02-04-2013 09:14 PM
Skimming that old wall ( continued )
Just a short note I had to try to do a finial coat to complete a smooth surface.
I watered down the mud J/C enough Rolled it on using a 3/4 " nap roller and used a squeegee to smooth the finial coat smooth as a babies butt. Cool !
Deck hand
