Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 07-08-2012, 08:40 AM   #1
Ge0ff
Skimcoat plaster
Hi folks! My first post. I've just come to the US from Ireland and have bought a house. Have started Sheetrocking and would like to skim the boards (with plaster, not mud). Any plasterers out there to answer my two questions ....... what is the brand name of a skim coat? And is there some type of PVA to get the skim to stick to the ivory side of the board. All I see in The Home Depot and local builder's providers are Uni-Kal and Structolite. Incidentally, can Structolite be spread on the ivory side of the Sheetrock?
Am a little apprehensive because of the seemingly high lime content reacting with the board paper
Any gypsum stockists locally? - Southern New Hampshire
Ge0ff is offline   Reply With Quote
Old 07-08-2012, 03:20 PM   #2
sdsester's Avatar
Skimcoat plaster
If you have a drywall substrate why not finish it off with hot mud (aka setting type compound) instead of plaster? You can mix it to whatever consistency you want and work it like plaster. You can, with experimentation add texture. I have even squeezed it through cake decorating tips to satisfy interior designers a time or two.
I am not sure what you hope to gain with actual plaster unless you are going to try to lime color in it or going for a polished Venetian plaster look or something. If either is your goal, I guess I would lay down a coat GARDZ first. Otherwise, just a quality sealer/primer should do.
I repaired plaster with plaster all the time but once I had drywall up I seldom saw a reason to coat it with plaster. If I were doing a Venetian look I would still use hot mud and cover it with artist's gesso or modeling paste. Something with marble dust in it. Wasted if you are just going to prime and paint it of course. Better to use a specialty paint with some metal or pearl in it I think?
Nothing against plaster by the way. And if you are trying to maintain that Burly-Manly-Man-Ring-of-Kerry look of yours, you should use a hawk and plaster because it weighs twice what compound does and those big biceps will attract psychotic red-headed women faster!
Not sure about Ireland but hot mud comes in a range of cure times ranging from something like 5 minutes to 120 minutes (hard to find the 120). 5 minutes starts the moment it sniffs a hint of moisture but is great if you can work fast and have somebody mixing for you. You should be able to get 5-90 at a real paint store. Not sure what the box stores carry since I do not shop in them.
sdsester is offline   Reply With Quote
The Following User Says Thank You to sdsester For This Useful Post:
Ge0ff (07-25-2012)
Old 07-10-2012, 08:21 AM   #3
Ge0ff
Skimcoat plaster
Thanks for that! Have read up on it and I think it's a goer.
Will Structolite stick to the ivory side of the board without PVA or other suchlike adhesives?
Old 07-10-2012, 10:30 AM   #4
sdsester's Avatar
Skimcoat plaster
I should think so but I have never used the branded Structolite product. You probably want to prime the sheetrock to seal it anyhow though.
Old 07-11-2012, 09:50 PM   #5
Ge0ff
Skimcoat plaster
What I'm afraid of is, that when the Structolite dries out it may blow in thick areas. No use trying a little area as the blow out might not happen for months. Will ring up the manufacturers on Friday. Thanks for the help
Old 07-13-2012, 12:16 AM   #6
Moderator
Skimcoat plaster
That is a technical question for the manufacturer, but for others reading this thread later, these may help for tips;
http://www.usg.com/usg-structo-lite-...t-plaster.html
http://www.usg.com/rc/installation-a...ps-en-P848.pdf
Our sister site; http://www.contractortalk.com/f49/structolite-92196/
Our "search" box; http://www.diychatroom.com/search.php?searchid=3157287
Gary
Clothes taking longer to dry?
The Following User Says Thank You to Gary in WA For This Useful Post:
Ge0ff (07-25-2012)
Old 08-12-2012, 09:49 PM   #7
Ge0ff
Skimcoat plaster
Thanks to all who helped. Finally got sorted with PlasterWeld and X-Kalibur. Excellent stuff ...... even if I have to drive 70 miles EW to pick it up.
Old 08-12-2012, 10:43 PM   #8
Skimcoat plaster
Love to see a pic or three of the final result!
Evstarr is offline   Reply With Quote
Old 08-18-2012, 12:18 PM   #9
Ge0ff
Skimcoat plaster
Will do.
Refinishing room-width cuts of plaster walls: will it work? Minich Drywall & Plaster 9 07-19-2011 09:28 PM
Bath remodel in 1947 house -- questions about plaster and plumbing Alix Remodeling 7 06-06-2011 10:12 PM
Venetian Plaster FYI Plaster Ayn Painting 10 07-01-2010 12:26 AM
Plaster Walls - Did I screw up? jamiedolan Building & Construction 5 11-07-2008 01:10 PM
Skim coat for damaged plaster walls slapdash Remodeling 4 10-14-2007 06:27 AM
