Skim Coating Problems. - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 12-12-2010, 01:47 PM   #1
Skim coating problems.
After skim coating a ceiling, there are several bubbles or non-adhesion areas. How can i repair?
Ron Zachwieja is offline   Reply With Quote
Old 12-12-2010, 10:57 PM   #2
What mixture did you use to skim coat the surface? I have experianced that before if I mixed the slump too thick. Try sanding down the mentioned areas and feather out the area. Re-skim it and see how that works.
MC Handyman is offline   Reply With Quote
The Following User Says Thank You to MC Handyman For This Useful Post:
Ron Zachwieja (12-13-2010)
Old 12-13-2010, 10:48 AM   #3
I probably had it too thick. I usually add water and mix to a consistency similar to sour cream but this time i was working in my daughter's house and didn't want to slop plaster all over the floors. Thanks for Your help.
Ron
Old 12-19-2010, 04:54 PM   #4
Smile
I thought that I thanked You earlier, but what I did was add another Post. Anyway, I think You are right. I usually mix the final coat to the consistency of sour cream and do not have this problem. This time I was skim coating my daughter's living room, left it a little thicker because I did not want to get slop all over her furniture, floors and walls. I'll fix after the Holidays. Thanks for Your help.
Ron
Old 12-19-2010, 07:40 PM   #5
Rewards Points: 256
in my expierience , bubbles are more caused by having a bad surface, loose paper etc . new mud losening old mud etc . if you scraped something and tore her paper its good to killz first.
oldrivers is offline   Reply With Quote
Old 12-20-2010, 08:39 AM   #6
Thanks!
The skim coating was done over a previously wet plastered surface.
I thought the same thing and repaired one of the spots with spackling paste.
That seems to work (better sticking stuff?).
Thanks again.
Ron
Old 12-20-2010, 08:37 PM   #7
Rewards Points: 256
yeah sometimes you wont know for sure until you do it, it happens ..
Skim Coating wall After removing wallpaper stevenson66 Painting 6 11-08-2010 07:35 PM
Skim coating exterior wood stromer3 Painting 3 05-12-2010 06:31 AM
Skim coating wood panel disaster krislb Remodeling 4 09-12-2009 11:13 AM
what trade do I call? skim coating Dusty General DIY Discussions 4 04-07-2009 10:53 AM
Roller skim coating - how to beerdog Painting 5 01-10-2009 11:00 AM
