Skim Coating The Entire Ceiling? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-16-2014, 10:42 AM   #1
Rewards Points: 384
Skim coating the entire ceiling?
After hacking the electrical in for 13 new can lights and running ethernet my ceiling looks like swiss cheese. I can patch the holes but since there is a texture on the ceiling it will be noticeable. I was thinking of after patching I hire someone to come in and just skim coat the entire ceiling. So...
1) Is this something someone will do? I'm assuming it's a horrible job to take on.
2) Is this my best option?
RyanD is offline   Reply With Quote
Old 01-16-2014, 10:46 AM   #2
Rewards Points: 12,856
Got a picture?
Old 01-16-2014, 11:37 AM   #3
Rewards Points: 6
A pic will help. Too late now, but it might have been easier to pull the whole ceiling and rehang it. Since you are in Mass, getting someone to skim coat with plaster should be easy.
Dan
djlandkpl is offline   Reply With Quote
Old 01-16-2014, 12:07 PM   #4
Rewards Points: 384
Why is that?
Here is an example of the holes I have to patch (the circles have lights now). And another picture showing where there was a wall and isn't anymore. I'll patch this too but it shows the texture I'm dealing with.
Skim coating the entire ceiling?-7rlov-gxnineecr4jziyz5jldfludbovh-3cid_xkjy.jpg   Skim coating the entire ceiling?-gov2mwx7s8zdpn3tkwjiahccfawvfs1tndpqnuup1zm.jpg
Old 01-16-2014, 12:27 PM   #5
Rewards Points: 6
New England is one of the few areas that still do skim coat plaster. I have the same sort of texture on my ceilings. It's completely random and sort of an art form. I can tell that at least two plasters did my ceilings as there is some variation between rooms.
It's something you could do yourself. I used drywall compound (vs plaster) and a wet sponge recently to repair a hole in my ceiling. Once it was painted, the patch disappeared.
Your job could be more palatable to a pro, if you have him do the walls.
Dan
Old 01-16-2014, 01:43 PM   #6
Rewards Points: 5,974
Can also patch and skim with joint compound and do it yourself. Then re-texture or leave smooth.
Old 01-16-2014, 06:31 PM   #7
Rewards Points: 384
Yeah, I'm going to get quotes for the entire drywall job but after getting a $3300 quote for electric and $1400 for one baseboard heat run I'm guessing the drywall quote will be way way too high so I was going to do the drywall and just get the ceiling professionally done.
How many coats would it take to skim over that texture though, in some parts it's 1/2 deep?
Old 01-16-2014, 06:58 PM   #8
Rewards Points: 6
I would fill the holes and try to feather in the texture. Are you looking for a smooth ceiling? If yes, I would just pull down the old and start from scratch. It will be faster and likely cheaper in the long run. Trying to skim 1/2" is too much in my opinion (not a pro).
Dan
Old 01-16-2014, 09:38 PM   #9
You can sand down the high points till it fairly smooth then skim. Don't try to fill 1/2".
Old 01-16-2014, 10:11 PM   #10
Rewards Points: 209
Mudding over popcorn ceiling...
Sorry
crayola110 is offline   Reply With Quote
Old 01-16-2014, 10:19 PM   #11
Rewards Points: 209
Mudding over popcorn ceiling. Prime and paint OR semi gloss
Phone error
Old 01-16-2014, 11:16 PM   #12
Davejss's Avatar
Rewards Points: 740
If it were me I'd just re-sheet the whole ceiling.
Davejss is offline   Reply With Quote
Old 01-17-2014, 07:57 AM   #13
Rewards Points: 384
Yeah, I did a ceiling before....next again.
Old 01-17-2014, 08:26 AM   #14
Replacing the whole ceiling would be a last resort.
Bad Ceiling Cracks in Entire House john0kirk General DIY Discussions 3 02-09-2012 07:06 AM
skim coating brick fireplace jimmy21 Tiling, ceramics, marble 12 05-29-2010 10:55 AM
Skim coating exterior wood stromer3 Painting 3 05-12-2010 07:31 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
Interior: Preserving Installation Screw Holes During Skim coating? Lovegasoline Building & Construction 4 09-29-2009 04:03 PM
