Skim Coat Over Knock-down Previously Covered By Wallpaper - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-15-2012, 05:10 PM   #1
Skim Coat over Knock-down previously covered by Wallpaper
I am working on a bathroom that originally had knock-down that the previous owners wallpapered over. I removed the wall paper to expose the original knock-down and did my best to remove the glue.
I primed the walls and have been skim coating followed by sanding to fill in the knock-down. After several coats of mud, I primed the walls again, skim coated, and sanded again.
It has been 4-5 skim coats of mud and I haven't been able to fill in all the knock-down. I have been using premixed joint topping compound, sanding with 220 grit, and priming with Kilz.
The hardware store suggested that I prime between each skim coat. I think the premixed joint topping compound is shrinking while drying exposing the knockdown.
Any tips or suggestions or do I just need to keep going?
jsmoe is offline   Reply With Quote
Old 08-15-2012, 08:27 PM   #2
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 908
You don't need to prime between skim coats.
Are you using the all purpose compound? If your using the light compound that could be part of the problem. But five skim coats should be plenty to cover the knockdown texture. Be sure not to sand all of the mud off between coats.
Sir MixAlot is offline   Reply With Quote
Old 08-16-2012, 07:53 AM   #3
I am using light compound and haven't been sanding extensively. Would using a sponge instead of sanding been better? What about using a roller and thinning the compound to apply it?
Old 08-16-2012, 11:31 AM   #4
Rewards Points: 908
You need to use the All Purpose joint compound. Not the light.
I think using a sponge to sand between coats will help too.
Old 08-29-2012, 03:28 PM   #5
Drywall contractor
Rewards Points: 1,070
Agree. Topping compound is very lightweight, scratches very easily, doesn't fill voids well, and (in my opinion) is totally a waste of time if you want a quality finish. I have used it on one or two occasions in years past where the contractor put it on the job. Have never bought any.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Tags
knock-down , primer , skim coating
Can I use Hendry 547 Unipro skim coat over Henry 555 or 565 SLC? jellybeanjugler Flooring 1 07-02-2012 06:08 AM
Textured paint over plaster skim over wallpaper? DIYchallenged Painting 1 07-18-2010 03:14 AM
Skim Coat bigfixer Painting 8 02-23-2010 11:42 PM
Liner to cover old wallpaper covered w/paint saggdevil Painting 4 05-24-2009 07:16 AM
How to Skim Coat Walls LeahMia1995 Remodeling 2 03-07-2008 01:25 PM
