Skim Coat On Cinder Blocks - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 12-19-2012, 07:54 PM   #1
Rewards Points: 119
Skim coat on cinder blocks
Hi all
Is it possible to skim coat cinder block walls, which are above grade, using drywall compound.
This is my garage, not looking for perfection, just a better base to paint white.
Thanks in advance for your help.
RH913RH is offline   Reply With Quote
Old 12-19-2012, 09:07 PM   #2
Rewards Points: 960
Go to a paint store and tell them what you want to do. They will sell you a blocker/primer.
You may compare the cost of the blocker & paint versus a skim coat of plaster. The fiber-reinforced plaster is not inexpensive and I wouldn't paint it afterwards. You may not feel comfortable troweling it on either.
cleveman is offline   Reply With Quote
Old 12-20-2012, 07:18 AM   #3
Rewards Points: 5,974
I just put this on another thread but I'll repeat it. There is a new product out called Fibra Fuse it comes in 36" width rolls and it is really good for skimming. Having said that I have no idea about concrete. I would go to their website and try to find out or call their 800#
Old 12-20-2012, 02:24 PM   #4
Mold!! Let's kill it!
Rewards Points: 2,012
If the blocks are exposed on the outside, they'll absorb a certain amount of moisture during a rain event. Any plaster type of coating or drywall compound will fail from the moisture absorbed. You could coat it with something like Thoroseal
http://www.thoroproducts.com/products_waterproofing.htm
or parge it with portland cement. Cinder blocks are even worse than concrete block since they are more porous.
The Following User Says Thank You to Maintenance 6 For This Useful Post:
ToolSeeker (01-02-2013)
Fix Bad Skim Coat Job smoline Drywall & Plaster 8 09-21-2012 09:36 AM
Second topcoat blisters over clean skim coat norepeat Painting 8 09-07-2011 06:30 PM
skim coat over skim coat? drke Drywall & Plaster 0 11-28-2010 09:07 AM
Skim Coat on Ceiling is Bubbling JerMann Painting 19 09-13-2010 09:37 PM
Skim Coat bigfixer Painting 8 02-23-2010 11:42 PM
