-   -   Skim coat on cinder blocks (http://www.diychatroom.com/f101/skim-coat-cinder-blocks-166937/)
RH913RH 12-19-2012 07:54 PM
Hi all
Is it possible to skim coat cinder block walls, which are above grade, using drywall compound.
This is my garage, not looking for perfection, just a better base to paint white.
Thanks in advance for your help.
cleveman 12-19-2012 09:07 PM
Go to a paint store and tell them what you want to do. They will sell you a blocker/primer.
You may compare the cost of the blocker & paint versus a skim coat of plaster. The fiber-reinforced plaster is not inexpensive and I wouldn't paint it afterwards. You may not feel comfortable troweling it on either.
ToolSeeker 12-20-2012 07:18 AM
I just put this on another thread but I'll repeat it. There is a new product out called Fibra Fuse it comes in 36" width rolls and it is really good for skimming. Having said that I have no idea about concrete. I would go to their website and try to find out or call their 800#
Maintenance 6 12-20-2012 02:24 PM
If the blocks are exposed on the outside, they'll absorb a certain amount of moisture during a rain event. Any plaster type of coating or drywall compound will fail from the moisture absorbed. You could coat it with something like Thoroseal
http://www.thoroproducts.com/products_waterproofing.htm
or parge it with portland cement. Cinder blocks are even worse than concrete block since they are more porous.
