Shower Walls - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-07-2010, 10:16 PM   #1
Shower walls
I'm re doing my master bath down to the studs. In the shower I'm using Hardi backer cement board then ceramic tile. Question is do I need a visqueen vapor barrier behind the backer board. I'm also insulating the stud spaces in the whole bath for sound control.
Thank you
If it's true that you learn from your mistakes- I'm getting one heck of an education
thumbkins is offline   Reply With Quote
Old 05-09-2010, 05:10 PM   #2
Handyman
Rewards Points: 512
Vapour barriers are to prevent moisture from temperature differences. If its an exterior wall, then yes. I always install a 6 mil sheet behind the Duroc anyway because people think that grout and caulking lasts forever.
For the cost, its worth it...cut it to a 1/8" below the top lip of the pan.
canadaclub is offline   Reply With Quote
Old 05-18-2010, 12:19 PM   #3
Rewards Points: 150
Old school was the visqueen behind the backer board.
That method has been superseded by surface applied water proofing like Kerdi, Nobel or Red Guard. I prefer Kerdi. You can go to Schluter.com to see the system.
kgphoto is offline   Reply With Quote
Old 05-19-2010, 02:10 PM   #4
Handyman
Rewards Points: 512
yeah kg but have you seen the price of that stuff?! lol
I also put 6mil behind the Duroc for the same reason..just takes a little more time
Old 05-19-2010, 02:38 PM   #5
Rewards Points: 150
The cost can be high, but always less than the damage from the water. There are ways to build hybrid systems that work well, but cost less.
It is important to mention that both tile and grout are NOT water proof, grout even less so.
Now that more people are taking longer and hotter (vapor pressure) showers, more often, the old systems can't keep up and you get mold and mildew. With the Kerdi, you can use standard drywall which is easy to carry and cut, compared to cement board, so you save some labor. You can also use Denshield with Kerdi Band and get a real nice hybrid system.
Old 05-19-2010, 07:46 PM   #6
Handyman
Rewards Points: 512
good point kg. It all depends on what people want to spend I suppose. Personally, I like the whole Kerdi system..especially the drainage system but until the cost comes down its still old school for me.
Old 05-19-2010, 09:14 PM   #7
Rewards Points: 150
It is all use nowadays. Really good stuff. Fast to install and works like a charm.
shower head and mixer valve on opposite walls scramble Plumbing 0 02-28-2010 12:50 PM
greenboard on custom shower walls wvgreg General DIY Discussions 13 09-20-2009 03:31 PM
Questions on waterproofing tile walls for shower with floor pan. HautingLu Tiling, ceramics, marble 11 09-18-2009 11:12 AM
Rotting shower walls PICTURE Sarah24 Kitchen & Bath Remodeling 6 05-10-2009 12:09 AM
Honey, I'm going to re-caulk the shower... homebound Remodeling 1 02-10-2009 09:11 AM
