Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 03-23-2010, 12:09 AM   #1
Shower Surround & drywall transition
My husband and I stripped a 6x8 bathroom to studs/plywood. We had a contractor remove the tub and replace with a new Sterling Accord Smooth tub & shower surround (3 piece surround). The attached picture shows the placement of the new tub/surround.
The tub & surround are level. The surround seems to be properly aligned to the studs with the exception of the rear panel corner where it meets the back panel. From the top inside corner to the top outside of the panel the distance from the shower panel to corresponding studs ranges from 5/8” to ¼”. How do we hang the drywall? Our dilemma is how to put up the drywall on the wall above the rear panel. I can figure how to “level” it from top to bottom, but how do we transition that piece of drywall to the remaining drywall it will but against just in front of the tub/surround? It seems like it would have to grade from 5/8” down to where it will smoothly transition to the abutted sheet, but we've never seen this before so dont know if it's doable and if so how.
mchull is offline   Reply With Quote
Old 03-23-2010, 07:55 AM   #2
Xtreme DIY'r
Most likely there were shims there before
Or they simply attached the drywall & it followed the angle of the wall
My bath has shim board on 2 walls to bring the wall level
Old 03-23-2010, 12:53 PM   #3
Drywall contractor
Yep, get creative with some shims...
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 08-18-2010, 03:51 PM   #4
Knows everything but that
I know this is an old thread but I just installed this exact tub surround and this issue is referenced in the installation instructions. The back (part furthest from the shower head) will just have a slightly angled wall above the surround and will then be pretty much level with the wall outside the shower. After taping and mudding, you can barely tell, especially with the shower rod in the exact location.
JakAHearts is offline   Reply With Quote
Old 08-18-2010, 04:44 PM   #5
So did the installer fail to bring the studs plumb and flush with each other with furring strips before installing the tub and surround? Also, is this tub truly 6 ft long? The OP dexcribes a 6X8 bathroom and pictures a tub that fits into the short wall space.
Jim F is offline   Reply With Quote
Old 08-19-2010, 04:31 PM   #6
No, the tub is not plumb and flush. Its built at an angle for some odd reason. Also, no, its not 6 feet long.... :D
Shower grout discoloration Teebadoe Kitchen & Bath Remodeling 2 11-03-2010 08:07 PM
creating new shower floor/ slope??? Bob Funk Plumbing 2 03-01-2010 05:22 PM
Shower has drywall (not green) can I install Cement board Right over it? jwhiteuwc Drywall & Plaster 14 02-03-2009 03:20 PM
Drywall around shower BFD8 Drywall & Plaster 16 01-07-2009 07:49 PM
Stand up shower surround ghall79 General Discussion 2 02-12-2008 09:04 PM
