Should I Replace Or Patch This Dry Wall? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-07-2011, 10:58 AM   #1
Question
Should I replace or patch this dry wall?
Hello All!
I've got a problem with a few walls in my house after some wayne scotting removal. Take a look at the attachment on this post. That is one of areas that I need to fix.
The choices I have I guess would be the following:
1) mud, sand and fix
2) cut out and replace
3) just slap some new drywall overtop
The 3rd option is out as I don't want to do a lazy fix. If I do, I want to make sure I do it right and just slapping drywall on top seems lazy to me.
The first option I'm worried about because I have zero experience with dry wall and think that would be a ton of work for a person that is inexperienced.
That leaves me with the second option of cutting off the old and replacing with new. There are a few corners (not shown in the photo) that worry me as they are "odd-angles" but again, I think it will still be easier for me to simply replace.
What do you think? Any information will be greatly appreciated!
Thanks in advance,
Lawrence
clearnew is offline   Reply With Quote
Old 03-07-2011, 11:22 AM   #2
Old School
Willie T's Avatar
I happen to enjoy skim coating. So I would just patch something like that.
Willie T
Old 03-07-2011, 11:39 AM   #3
DIY staff
Rewards Points: 7,174
And I'm very efficient with drywall installation--so I'd replace.
Willie T (03-07-2011)
Old 03-07-2011, 12:28 PM   #4
Finisher
Since you will have to mud anyways whether you replace or repair, I would just repair.
Rcon is offline   Reply With Quote
Old 03-07-2011, 01:48 PM   #5
Ha! So we've got 2 repair and one replace. I think I may try repair first and see what happens. If I completely blow it, I'll replace.
Old 03-07-2011, 01:58 PM   #6
DIY staff
Prime that raw paper well before attempting to skim coat. If you don't the paper will lift when the mud soaks it.
I suggest green bucket(multi purpose) for the first coat or two---it contains glue and will grab the painted drywall very well---milti purpose is rather hard to sand--consider using blue lid for the top coat--(Light weight) it is much easier to sand.---Mike---
Old 03-07-2011, 02:12 PM   #7
Rewards Points: 558
Remove any excess ripped drywall, prime and skim coat as suggested…
epson is offline   Reply With Quote
Old 03-07-2011, 02:14 PM   #8
Old School
Willie T's Avatar
If you end up replacing, which is actually easier for most novices than patching, you might consider using "butt boards" when hanging the drywall. They eliminate, completely, the problems associated with the 'humps' usually found where the ends of two boards meet.
Willie T
Tags
dry wall , dry wall problems , patch , replace
Need to replace two tiles on brand new wall spidrw Kitchen & Bath Remodeling 5 04-29-2010 05:28 AM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 12:55 PM
Patch cement block wall? k.kuenn Building & Construction 4 05-31-2009 07:40 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
